99 PreRunner with 208k. What preventative maintenance should I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zer0, Dec 17, 2013.
  1. Dec 17, 2013 at 11:58 PM
    Zer0
    Zer0 [OP] Well-Known Member
    SGV, California
    99 PreRunner
    Just wondering what you guys recommend for preventative maintenance? I have 208k. I have a 2.7L automatic. When should i change out timing belt and water pump etc..
    Also, how can I tell if my suspension is blown....the shocks, leafs, bushings...etc.? My ride is stiff and bouncy. Passenger side is about an inch lower than the driverside.
    Thanks.
  2. Dec 18, 2013 at 8:20 AM
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    If your stock leafs are flat or have a negative arch (curving downward) then it's time for replacement packs. An Add-a-Leaf is no good in this situation as your main source of suspension is already worn out. If all the suspension is stock with 208k on it, its most likely time for new shocks and springs all around. I have 180k on stock stuff and will be replacing all shocks, coils, leafs, and hardware after the holidays.
  3. Dec 18, 2013 at 8:21 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Timing belt should have been changed at 100k. If not I recommend immediately. Even if no signs of issue just piece of mind it's done.
  4. Dec 18, 2013 at 11:08 AM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    2.7 has a timing chain.
  5. Dec 18, 2013 at 9:20 PM
    Zer0
    SGV, California
    99 PreRunner
    Thats awesome! Mine is a 2.7L Prerunner. Thought I had the rubber timing belt. Do I need to change out the chain or get it lubed or anything? Thanks.
  6. Dec 18, 2013 at 11:51 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    The timing chain should be fine until it starts to stretch and then when it stretches enough it can wear through the timing cover and then it needs to be replaced. You'll hear it when it starts rattling against the timing cover though.
