99 Satoshi Grille
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backpacksr5, Jan 25, 2016.
  1. Jan 25, 2016 at 6:21 PM
    Backpacksr5
    Backpacksr5 [OP] New Member
    1999 Tacoma SR5 4x4
    Well, I've seen these done before, but a Google search doesn't turn up very many results, so I thought I'd shareIMG_20160123_195659825.jpg mine. It took some figuring out (I don't pretend to be good at bodywork), but it turned out pretty much ok. The zip ties you can see in the picture holding the emblem on were temporary, just hadnt bolted it on yet.IMG_20160123_195639524.jpg IMG_20160124_082555340.jpg
  2. Jan 25, 2016 at 6:29 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Nice job! I like how you created a larger cross bar for the bottom of the grill instead of the thin stock part. I personally only ever made one of the 98-00 style grills.
  3. Jan 25, 2016 at 6:39 PM
    Backpacksr5
    1999 Tacoma SR5 4x4
    Thanks! I've seen your work, and it was one of the few examples I was able to use for inspiration. I'd like to take credit for that lower crossbar, but that's actually stock. Cutting out the stock Toyota oval left a nasty hole in it, though, so I had to fiberglass that in, just like the spots where the middle crossbar came out. Here's the before pic, it probably makes more sense than my descriptionIMG_20150918_124146210.jpg
  4. Jan 25, 2016 at 6:49 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Been a while since I really took a close look at one of them... :oops:
    I see what you mean. I removed both cross bars and just retained the thin strip on the bottom when I built one for @MTgirl
    Bigger opening but more fragile design. I've also seen a few where the bottom was reinforced to be thicker & sturdier.
    Pics like this make me miss my 99. :pout:
  5. Jan 25, 2016 at 6:55 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  6. Jan 25, 2016 at 7:24 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :angrygirl:
  7. Jan 26, 2016 at 2:48 PM
    stumpman
    stumpman Well-Known Member
    tn
    2019 Dclb cement
    Looks good, love the Toyota lettering.
