99 sr5 3.4l 4x4 automatic hard shifting into neutral at stop.
Discussion in '1st Gen. Tacomas (1995-2004)' started by thewaydown, Aug 5, 2016.
  1. Aug 5, 2016 at 4:51 PM
    thewaydown
    thewaydown [OP] Active Member
    Zayne
    1999 White Tacoma 3.4l v6
    My Tacoma has 200,000 miles on it. I just got the transmission fluid flushed, although this problem was happening before the flush, so i'm sure that's not the culprit.
    If I dont slowly roll up to a stop (very slowly) it shifts hard into neutral. It doesnt hard shift back into 1st when I take off though, unless I stop really fast and then step on the gas again immediately, it will hesitate to shift into first gear and rev up until it kicks in.
    Is this a sign my transmission is going? Should I sell it before it gets any worse? I really dont want to put any more money into this truck.
  2. Aug 6, 2016 at 5:18 PM
    Badmood
    Badmood Well-Known Member
    Leawood, KS
    2000 Lunar Mist TRD
    driveshaft slip joint, carrier bearing, and axle wrap. 1 if not all.....
  3. Aug 6, 2016 at 6:54 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    So your tranny shifts into neutral without you physically doing it? Cause an auto dosent go into neutral at a stop it will always be in gear unless you shift into neutral. So im guessing it is hard shifting into 1st gear at a stop?? Just trying to clarify whats going on here...
    thewaydown[OP] likes this.
  4. Aug 6, 2016 at 6:57 PM
    Clearwater Bill
    Billy
    Largo Florida
    Classic worn clutch packs
  5. Aug 6, 2016 at 8:04 PM
    thewaydown
    Zayne
    It really seems like it is slipping into neutral, yes without me physically shifting it. It may be shifting hard back into first, but as I said, If I stop really quickly, and then step on the gas again within 2-5 seconds, it will rev up as if its in neutral, and then kick into first gear. Its odd.
  6. Aug 6, 2016 at 8:05 PM
    thewaydown
    Zayne
    Do you have any idea how expensive the job is? I doubt it's something I could do myself. I've already put 3 grand into it in repairs in the past few months.
  7. Aug 6, 2016 at 8:53 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Typical symptoms of transmission slipping. Have you checked the transmission fluid level? If the fluid level is fine, then I'd be thinking worn out clutch packs.
  8. Aug 7, 2016 at 4:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'd not hazard a guess, other than 'not cheap'.
    And yes, it's a job for a pro. You might be well served to find a used transmission with a decent warranty and more modest miles.
    Member @gearcruncher might be able to give some clues on current pricing.
  9. Aug 7, 2016 at 5:43 AM
    blahh104
    blahh104 Member
    2017 ext cab trd sport
    This was just happening to me on my 02. Turned out there was a crack in the dipstick tube and I was very low on fluid. Once that was replaced with new fluid and filter its driving fine again.
  10. Aug 9, 2016 at 12:06 PM
    gearcruncher
    Canadain bumper technician
    I agree that at low fluid issue would cause this .
    It would be great to hear back from the OP to see if he checked his fluid properly
  11. Aug 11, 2016 at 12:36 PM
    thewaydown
    Zayne
    I have such a hard time checking the fluid level on this thing considering the angle of the dipstick. By the time I pull it out there is no definitive line on either side of the stick.
    Here's what I do:
    Get the truck up to operating temperature.
    Shift through gears.
    Check level with engine running.
    Should I wait a little while after shifting through the gears (with engine still running) and then check the level?
    I'm pretty sure it shouldn't be low as I don't see a leak, and I just had my transmission fluid flushed about a month ago.
    Also, does anyone know if Lucas transmission fix would help/hurt at all?
