99 Tacoma 2.4L AUTOMATIC turbo?
Discussion in 'Performance and Tuning' started by Justinking2012, Mar 6, 2012.
  1. Mar 6, 2012 at 8:56 AM
    Justinking2012
    Justinking2012 [OP] New Member
    Is a turbo on an automatic bad?
  2. Mar 6, 2012 at 9:02 AM
    Justinking2012
    Explain please....
  3. Mar 6, 2012 at 9:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not bad at all. Just need to know how much power that your auto can handle. CustomTacos.com has a ton of info on your style truck, being boosted.
    Generally speaking, turbos on automatics spool quicker than same setup on a manual
  4. Mar 12, 2012 at 11:13 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    If you plan on lightly boosting you're truck (5-8psi), you MAY get away with a stock tranny, depending on other supporting mods. I would strongly recommend upgrading your valve body in the transmission as a bare minimum. Turbo's an automatics are great when done right, otherwise you are looking at many headaches. Especially if this is a DD.
  5. Mar 12, 2012 at 11:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea turbos with an auto are much faster usually then manual as the shifts can be made much faster and the RPM loss isn't as great therefore the turbo stays spooled better.
    However..as stated before..usually you have to beef up the auto a bit more..Check out Customtacos.com. MUCH MUCH more info there for turbo tacos.
