99 Tacoma 2.7 egr vsv
Discussion in '4 Cylinder' started by yodaman7, Sep 4, 2012.
  1. Sep 4, 2012 at 9:58 PM
    yodaman7
    yodaman7 [OP] New Member
    Dakota
    Lancaster,CA
    1999 Prerunner Red
    Tires, intake, hopefully much more to come.
    Hello everyone!
    I have a 1999 Toyota Tacoma 2.7 and unfortunately I believe my vsv for my egr went out unfortunately I cannot locate it :/ I'm new to my Toyota and I'm hoping I might be able to get some feedback on where I can find it so I can get my baby running right.
    Thank you for your time and I greatly appreciate all information
    -yodaman7
  2. Sep 6, 2012 at 11:08 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Welcome to TW! When you mention your VSV went out, was there a code or what? I think it would be a good idea to verify the failed part before buying a replacement. Can you give us some background on what you had found so far?
  3. Sep 6, 2012 at 12:41 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    I believe that the EGR VSV is located directly below the throttle body, in the 'cave' formed by the intake manifold. Hard to get at without removing the throttle body. When my 2.7 thru a P0401 code a while back, I had thought that could be the problem, but it turned out to be the EGR temp sensor. Removed that, cleaned it real good, and re-installed it. No issues since.
    Hope this helps.
  4. Oct 29, 2013 at 7:24 PM
    calimondin
    calimondin New Member
    ben
    tampa,fl
    1999 toyota tacoma
    under the intake manifold, its green in color , you can remove it if your hand is not to thick. use long phillips screwdriver to remove one small bolt, put a sticky something to screwdriver end to hold bolt,its easy to loose. disconnect elect. plug . disconect vacuum hoses from egr equipt and pull out.remove any spacers from tubing before easing it out. good luck.
    Jesus H. likes this.
