99 Tacoma 2wd suspension help...
Discussion in '1st Gen. Tacomas (1995-2004)' started by splice35mm, Nov 9, 2010.
  1. Nov 9, 2010 at 11:52 AM
    splice35mm
    splice35mm [OP] Member
    Tim
    Simi Valley, CA
    2002 Tacoma Xtra Cab 2wd
    Hey all. Looking for advice to improve the suspension on my retired gardening truck (not really), now used as an everyday commuter and for hauling dirt bikes. I just ordered a set of Bilstein HD shocks for starters, but I hear rumors that the stock rear leafs are crap. True? They seem ok, I guess. I tend to drive at pretty high speeds on dirt roads with a full load, and they aren't bottoming or anything. I bought it used and it came with a sway bar still in the box. Worth installing?
    This Taco only has 106,000 miles on it. Should I think about replacing front end bushings? Anything else I should consider?
    Thanks in advance for any advice. I absolutely love this stupid little truck, and I can't quite figure out why!!!
  2. Nov 9, 2010 at 12:53 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Its all subjective I guess, I personally think the rear leaf springs are pretty shitty, but if your a little heavy on the gas any upgrade in suspension will be worth it, & the answer to your wondering why you love your truck is simple: You beat the hell out of it & it doesn't complain.... happy trails
  3. Nov 9, 2010 at 1:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is it a 5 lugger? Springs mounted under the rear axle or on top of the axle?
  4. Nov 9, 2010 at 2:14 PM
    splice35mm
    Tim
    Simi Valley, CA
    5 lug. Not sure about where the springs are mounted, but I'll take a look in a little bit. Pretty sure everything is bone stock.
  5. Nov 9, 2010 at 3:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Most of the rear spring problems you read about on here apply to the 6 luugers with their spring over applications. I can't offer much advice for 5 luggers. Had one once, a long time ago ('93). Never had any issues with it but then, it didn't have very many miles on it.
  6. Nov 10, 2010 at 11:31 AM
    splice35mm
    Tim
    Simi Valley, CA
    Great. Thanks. The leafs don't seem to be broke.... so I won't fix them.
  7. Nov 15, 2010 at 8:34 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I have a 5 lug with 80k. My springs are still in great shape. They don't have a lot of arch in them unloaded but that's just how they are... I pull around my mowing trailer every day and it doesn't even level the truck out. I'd say you're fine with just doing shocks, but watch out when ordering suspension stuff. You'll find that virtually nothing fits 5 lug trucks... :frusty:
