99 Tacoma 2wd w/ SR5 prerunner springs and jeep spacers work???
Discussion in 'Suspension' started by Street, Aug 9, 2012.
  1. Aug 9, 2012 at 12:15 AM
    Street
    Street [OP] Well-Known Member
    jon
    Brevard
    Tacoma
    Hey guys 99 2.4 5 lug
    got the 3in body lift on it
    just picked up some SR5 Prerunner Springs NOTE i have Coils Springs not Struts
    was looking to put them under the front with a set on 04 jeep wrangler coil springs spacers around two inches I know this is weird but looks like it will work but I need to know b/c i see alot of you guys changing out the upper control arms I'm not one to do alot of off road driving just looking to jack her up, any ideas on this do i need upper control arms for some type of clearance reasons or if it fits ride on?
    So re Cap SR5 prerunner coil springs with 04 jeep wrangler coil spring spacers if i'm missing something please let me know, thx Jon
  2. Aug 9, 2012 at 4:55 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Do they have the correct bolt pattern for the 3 nuts holding the coils on? if so I don't see why not.
  3. Aug 10, 2012 at 12:16 AM
    Street
    jon
    Brevard
    Tacoma
    no Sir I got fucked on mine its got Str8 Coils not coilovers has the shock by its self
  4. Aug 10, 2012 at 8:25 AM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Hmm I am not sure than, really don't know much about that suspension
  5. Aug 11, 2012 at 10:18 PM
    Street
    jon
    Brevard
    Tacoma
    yeah like i said I got screwed over on my susp.
  6. Aug 15, 2012 at 5:31 PM
    Street
    jon
    Brevard
    Tacoma
    forums blow!!!!!!:mad:
  7. Aug 15, 2012 at 6:45 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Sell truck, buy a better one. Win :D
  8. Dec 5, 2012 at 9:17 AM
    vincentek9
    vincentek9 Member
    Vincent
    Orange County, CA
    96 2WD taco
    roundeyes, visors, wink mirror, level kit
    kind of late, but i think all 1st and 2nd gen tacomas do NOT have necessarily the same suspension setup.
    4x4 and prerunners have an entire coilover-type suspension in the front. where the spring sits on the strut. when changing suspension, the entire thing unbolts as a unit
    5lug tacomas have a different type of front end set-up (a much shittier version). where the coil spring sits on the lca's rather than on the shock itself. when trying to change this out.. there are goods and bads. if i recall correctly, changing out the shock is simple because it does not requiring removal of the spring. but changing out the spring could be a hassle because the angle is so wierd that you have to put a spring compresser at the right spots to ensure you pull out the spring without issue.
