99 Tacoma 3.4L hesitates at full throttle
Discussion in '1st Gen. Tacomas (1995-2004)' started by aldoraine, Aug 17, 2012.
  1. Aug 17, 2012 at 12:07 PM
    aldoraine
    aldoraine [OP] Well-Known Member
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Like the title says I have a 1999 Tacoma 3.4v6 automatic, 4WD and for some reason, the truck is unresponsive and hesitates at full throttle, but as soon as I let off to about 3/4 throttle, I feel it pulling like it should, just doesn't really accelerate at full throttle, but revs up just fine.
    So far I've:
    -Replaced Spark Plugs
    -New Plug Wires
    -Cleaned MAF with MAF cleaner
    -Air Filter
    -Seafoam through the tank
    -Oil / Filter Change
    Any Ideas? It's got 210,000 and runs like a champion, however It's got a check engine light on, (Last time I had it checked, it was PO171, engine too lean bank 1?) But it does it regardless if the light is on or not. I can reset the code, and it goes away for a day or so, then comes back.
  2. Aug 17, 2012 at 12:30 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Maybe this will help.
  3. Aug 17, 2012 at 12:35 PM
    98tacoma27
    Ben
    Not Beech Creek
    Resetting the code doesn't change the lean condition. With that many miles, you probably need to change the AFR (aka front O2) sensor.
  4. Aug 17, 2012 at 2:47 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    I changed both of mine at 177,000 miles after doing a tune up, no check light was on but they were dirty..
    made all the difference in running and mileage
  5. Aug 17, 2012 at 3:18 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Thanks, sounds like I know what to do next. Hopefully that fixes the issue. Not that I pass, or floor it very often, but It would be nice to have the power be there when I need it. Thanks for the replies, and the Images!
  6. Aug 17, 2012 at 3:21 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    When I bought my truck the light was on and just like yours it would fall on its face when I would floor it but I could let off a little and it would gain speed. The problem turned out to be the maf. I cleaned it and it didn't make a difference, so I replaced it and that fixed it. The maf was bad and it wasn't reading that the truck was sucking in more air at full throttle, thus not letting the engine get enough fuel.
    cruxofthebisquit likes this.
  7. Aug 17, 2012 at 4:31 PM
    Madjik_Man
    Colorado Front Range
  8. Aug 17, 2012 at 4:56 PM
    Southern01Taco
    Sean
    Holden, La
    Its easy, but be careful because I broke one of the studs on accident. Luckily one stud is enough to keep it from leaking or anything.
  9. Aug 17, 2012 at 4:58 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    its not too hard, just tight for adult or wide hands. i went by this
    http://www.lieblweb.com/o2replacement.html
    YES,,,, spend 5 days soaking it with power blaster, give it a shot in the morning.... to help loosen the nuts.
  10. Aug 18, 2012 at 4:52 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    http://www.yotatech.com/f2/changing-oxygen-sensor-when-nuts-rusted-197311/
    and if you need tips for bad rust read this.
    not trying to sell you anything, but its been my experience that you should change both while you are at it. 2 fresh ones seem to work better than a new one and a old one.
    and alot of soot that covered my old ones fell off before I could take a pic... these were the worst ones I had ever seen.
  11. Aug 18, 2012 at 7:09 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    Two things to consider. First, how rusted are the studs/nuts? That can be a PITA and some people have already posted remedies for that.
    Second, is it an automatic or a manual. The automatic is no problem. The connector for the O2 sensor is on the right side of the trans. Easy to get to...well easier than the manual.
    With the manual, you have to remove the console around the shifter. Then remove the boot. You also have to remove the 4x4 selector boot, if you have 4x4. The connector is stuck on top of the trans and attached to a bracket. I removed the bolt from the bell housing to get the bracket to the opening by the shifters to get it apart. Then connect the new one and drop it down to put in the exhaust pipe.
    I have done both and the auto is much easier...IMHO.
  12. Sep 19, 2012 at 8:17 AM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Little update on this.. I changed out the o2 sensors (both front and rear) and the problem is still there. Still throwing the code and still isn't happy at full throttle. Any other ideas?
  13. Sep 19, 2012 at 8:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    Have you done anything else or just replaced the sensors?
  14. Sep 19, 2012 at 8:27 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    Did you check the coil packs or ignition coils (may be same thing--it's what sits on top of the spark plugs). When I had my last '00 Tacoma, I was going down the road just fine one day and then it started missing and I noticed white smoke coming out the exhaust. Long story short, some how, one of the spark plugs had came out and was firing up into the coil pack. Damaged both. Ended having to put a helicoil down in the head to hold the new spark plug.
  15. Sep 19, 2012 at 9:06 AM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    So far I've:
    -New Plug Wires
    -Air Filter
    -o2 sensor front and rear.
    The truck runs beautifully besides full throttle, it's the weirdest thing. Idles correctly, sounds just fine. But for some reason, at full throttle, the truck downshifts, and the engine revs up, but it doesn't really make any power. However, if I just let off the throttle to about 3/4, it takes off. Strange... I've noticed on steep grades if the engine is under heavy load under about 3k rpm, there is a slight pinging.
    EDIT: Was just doing some searching, and came across a YotaTech thread where a guy mentions when his MAF was going bad he had no full throttle power, maybe I'll take it out and try cleaning it again, or replace that next. Sound feasible?
    http://www.yotatech.com/f16/problem-accelleration-98-4runner-60044/
  16. Sep 19, 2012 at 9:34 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    as far as hesitation at full throttle...
    I didn't see "fuel filter" on your check list
  17. Sep 19, 2012 at 9:37 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's a possibility
    ^Also a cheap thing to replace to rule it out before purchasing a new MAF.
  18. Sep 19, 2012 at 11:52 AM
    Southern01Taco
    Sean
    Holden, La
    Quoted just in case you missed my post earlier in the thread. The maf cost me 75 bucks but had a $60 core charge.
  19. Sep 19, 2012 at 3:54 PM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    i believe that it could be your maf ive been having alot of problems lateley had no power on my 2.7 changed everything and checked everything. I threw a maf code twice when i first had it cleaned it both times and the code never came back. But i started losing power gradually until here i am hOrrible power and doesnt rev. pulled my plugs and they are whitish brown very little black at all around the plug. it bogs everywhere and anything over 1/2 to 3/4 it doesnt really rev at all.
    Just my 2 cents. It been bugging me for ever hope you fix your problem and report back. may have to hit the junk yard to test one out
  20. Sep 20, 2012 at 6:48 PM
    aldoraine
    evan
    vallecito ca
    99 Tacoma 4WD TRD
    Just to follow up on this, I fixed the issue. It was the MAF sensor. I went and picked one up from Kragen for $75 (Re-manufactued Toyota OEM by A1Cardone) and it runs beautifully now. For those of you doing this, be careful when removing the Air Box for MAF replacement. I snapped my airbox where the MAF housing tube meets the box. It's extremely weak right there and any pressure on it will most likely snap it.
