99 Tacoma 4x4 4 cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by sac1954, Jan 24, 2024.
  1. Jan 24, 2024 at 12:16 PM
    sac1954
    sac1954 [OP] New Member
    99 Tacoma 4x4
    Greetings TW. My power steering screamed for several years and finally stopped working. First I cleaned out the reservoir and flushed the lines. No good. Next I replaced pump and bleed the lines. Now the fluid is flowing out from under the cap on reservoir and no power steering. Please help with next step. Thanks
  2. Jan 24, 2024 at 12:40 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    when u say 'cleaned reservoir' did you clean the incorporated screen inside the res?
    mine took 4 freakin cans of brake cleaner to get presentable and let enough fluid to get into entire system
  3. Jan 24, 2024 at 4:11 PM
    jabberjawmash
    jabberjawmash Well-Known Member
    Jackerz
    95Tacoma
    Mine was screaming too, replaced the 6203 bearing with a nice nachi one and it fixed it!
    I put the front end on stands and ran the engine and rotated the wheel in both directions to suck up the fluid. Worked well and still works.
  4. Jan 25, 2024 at 7:51 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It sounds like the screen was never cleaned completely !
    No pressure because the pump is starving for fluid!!
    Poor quality pump?
    The power steering is bled by turning the wheels lock to lock not cracking the lines!!
    ATF not power steering fluid !!
  5. Jan 26, 2024 at 6:40 AM
    jabberjawmash
    Jackerz
    95Tacoma
    Dex/merc atf! but yes you need to cycle the steering rack while the engine is running to bleed properly. Fun!
  6. Jan 26, 2024 at 7:51 AM
    sac1954
    99 Tacoma 4x4
    i cleaned the screen and cleaner poured thru it. Could see light all the way thru the screen (just under the size of a dime). I have cranked the steering wheel lock to lock about 20 times....I'm going to drain, flush, refill and bleed all over again. Will advise if that works. Thanks
  7. Jan 26, 2024 at 8:25 AM
    Bivouac
    Just where did your pump come from? Some very poor quality remans on the market.
    My thinking you just received a bad pump take it back !!
    Best of luck!!
  8. Jan 26, 2024 at 9:06 AM
    sac1954
    99 Tacoma 4x4
    Rock Auto - been using them forever for all my vehicles. Never had any issues with parts.
