99 Tacoma 4x4 rack & pinon replacement ????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ronnietacoma99, Feb 7, 2015.
  1. Feb 7, 2015 at 5:49 PM
    Ronnietacoma99
    Ronnietacoma99 [OP] Well-Known Member
    Ronnie
    Georgia
    99 SR5 4x4 2" lift 32"s
    Small maybe 2" lift, 32 x 11.50 mud terrains, TRD dual exhaust, train horns with compressor built in the tool box, 2 12a and a system that will blow your mind, new cvs
    I just bought a 99 Tacoma 4x4 v6 and the steering gear box is leaking pretty bad, not to the point that I notice power steering fluid on the ground but I see it all over the gear box and the frame. I've dec to replace the entire rack and pinon unit and I was wondering what else should be replaced while I have it apart??? I'm new to the tacoma world but I love the truck so far.
  2. Feb 7, 2015 at 6:52 PM
    06TRDsport
    06TRDsport Well-Known Member
    Bend, OR
    2007 F250 Diesel and 1999 4Runner
    A new rack should come with inner tie rod ends so you should only need new outer tie rod ends. It would also be a good time to make sure the upper and lower ball joints are good.
  3. Feb 7, 2015 at 7:16 PM
    Ronnietacoma99
    Ronnie
    Georgia
    The ball joints and cv axles are new, what about bushings up front? Are there any associated with the rack and pinon?
  4. Feb 7, 2015 at 7:37 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Rack, outer TREs, rack bushing kit, and fluid of your choice should cover it. Since you are going to need an alignment anyway, I would do the upper and lower A arm bushings too. But, that's just me.
  5. Feb 7, 2015 at 7:43 PM
    Ronnietacoma99
    Ronnie
    Georgia
    Do they make a poly rack bushing kit? Or do you think the new rack will come with new bushing?
  6. Feb 7, 2015 at 8:05 PM
    Broke Okie Ty
    Ty
    I think energy suspension makes poly bushing. I'd buy their bushings no matter if a new rack came with bushings.
  7. Feb 11, 2015 at 2:23 PM
    sirotto
    sirotto Well-Known Member
    Indy
    Taco with a man pedal
    Bone stock
