99 tacoma a\c problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by derbyl73, Jul 4, 2016.
  1. Jul 4, 2016 at 5:26 PM
    derbyl73
    derbyl73 [OP] New Member
    1999 White SR5
    My air worked fine last time i parked it. Got in it and now clutch wont engage on compressor. I took it to a guy and he said it wont take freon. I have 14.4 volts at clutch and good ground. Checked with ohm meter and had 4.4 ohms. I went ahead and replaced compressor clutch thinking it must be bad since I have voltage and ground. Still same thing with new one. Any suggestions would help. Im at a loss on this one.
  2. Jul 4, 2016 at 5:59 PM
    tacoman1994
    tacoman1994 New Member
    Cody
    Nova Scotia Canada
    2000 Tacoma 4x4 v6
    currently working on a custom front tube bumper - bushwhacker flares
    You could check in the fuse box maybe a relay problem or fuse problem
  3. Jul 4, 2016 at 6:02 PM
    derbyl73
    1999 White SR5
    Checked the fuse, it is good. No relay to be found. I dont understand how im getting battery voltage to coil and its not engaging clutch. Maybe new coil is faulty also. Im at a loss.
  4. Jul 4, 2016 at 6:14 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    If the guy says it won't take refrigerant, and he doesn't know why, you should take the truck to a seasoned a/c tech who won't throw parts at it until it's fixed..... just sayin'.
  5. Jul 4, 2016 at 6:19 PM
    derbyl73
    1999 White SR5
    It is a buddy of mine who is a tractor mechanic. I asked him to see if it needed freon. I assumed it was the coil since it had correct voltage and ground and wouldnt engage. So i threw the part at it. Ive mechaniced for 25 years but i dont do ac work for that reason.
  6. Jul 5, 2016 at 1:56 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    So both the old AC clutch and the new one don`t pull in .
    Even with Battery Voltage to the Clutch ??
    Where are you measuring the Voltage at the plug ??
    Corroded connection works with the Meter probe but not when plugged in . This is enough to drive any of us crazy!!
    Jumper the AC clutch direct from the battery ??see if it pulls in
    In this day quite possible you got a bad one out of the box .
    Was it new or untested used one ??
  7. Jul 5, 2016 at 3:54 AM
    derbyl73
    1999 White SR5
    Yes measured at the plug. Its a single wire denso compressor. Also tried jumper wire from battery and nothing. Bought a new one from autozone. I normally dont shop there but they were only one that offers just the coil.
