99 Tacoma...Bizzar Event at Best!
Discussion in '1st Gen. Tacomas (1995-2004)' started by gedeuce, Aug 24, 2019.
  1. Aug 24, 2019 at 6:35 PM
    gedeuce
    gedeuce [OP] Member
    1999 Toyota Tacoma
    none
    Had my 99 4x4 Tacoma out for a spin. I slowed down to make a stop, and suddenly noticed that the truck was running but was not in gear.....any gear. I stopped, and tried to move the truck in all gears. Nothing. I could even put the tranny in any gear without depressing the clutch!!! I began fooling around with the 4x4 tranny and gearshift....by engaging and unengaging the 4x4 and shifting from low to hi with the 4x4 tranny. All of a sudden the truck is back to normal. I have been driving it for weeks now with no similar problems. I'm completely baffled by this. Has anyone else ever had this occur? If so, what is going on? Its a 3.4 L V6 with manual tranny and manual 4x4 shift.
  2. Aug 25, 2019 at 2:50 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can only guess somehow you bumped the transfer case into neutral.
    Maybe it was just not fully engaged in 2wd and popped out
  3. Aug 25, 2019 at 2:49 PM
    gedeuce
    gedeuce [OP] Member
    1999 Toyota Tacoma
    none
    I will test out your theory. Thanks for responding!
