99 tacoma coolant reservoir spews
Discussion in '1st Gen. Tacomas (1995-2004)' started by j4roe, Mar 22, 2010.
  1. Mar 22, 2010 at 3:52 PM
    j4roe
    j4roe [OP] Active Member
    joe
    phx
    prerunner 3.4
    Fox coilovers, prerunner bumper with skid plate, flaired front fenders, CAI, throttle body spacer, flowmaster 40 series exhaust, 33 bfgoodrich Baja all terrain tires, billstein 5500 rear shocks with Deaver leafs....
    I have a 99 3.4, a couple of times now on roadtrips, out of nowhere the reservoir just spews while I'm driving, but the truck temp stays the same and the radiator is still full. The first couple of times I thought the Res. Cap had come off because u can see the coolant spewing out onto my Hood between the Hood and flaired fender. The cap is definitely on, so why do I keep spewing out of the reservoir?????? It only happens on the highway and usually at high rpms above 70 MPH.......... help please.
  2. Mar 23, 2010 at 7:27 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Your truck is overheating, and the cap is at max pressure, releasing the coolant in to the resevoir.
    Check your heads in the back, by the firewall. That's where they usually start to leak. Also check out your water pump for leakage.
