99 Tacoma crank no start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timshane 77, May 5, 2020.
  1. May 5, 2020 at 10:25 AM
    Timshane 77
    Timshane 77 [OP] Member
    Tim
    1999 Tacoma SR5
    I need help. My 99 Tacoma 2.7 with 250,000 was running great until last Friday. I got home from work, parked and when I went to start it to go get something to eat it tried to start then died. It now only turns over seemingly much faster than before. I checked to make sure it was getting fuel at the rail. It is. I pulled a plug to check for spark and it is firing. I'm at a loss. Could it have jumped time? I have read these timing chains are a lifetime part. I need help without having to spend a lot of money at a shop. I have extra time on my hands since I am now on furlough.
  2. May 5, 2020 at 10:27 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  3. May 5, 2020 at 1:16 PM
    j4roe
    j4roe Well-Known Member
    Joe
    Phx, AZ
    1st Gen
    Solo Motorsports 3.5 with heimed tubular uppers, Total Chaos spindle gusset, King 8" CO, Glassworks 3'' front glass, tube bumper, 4 25w 1000L Bumper LED, 2 Rigid Pod lights, 35" Toyo Open Country AT, Fiberworx 3'' Bedsides, Deaver F55, Custom 9" Shackle, Bilstein 7100 14" 2.0 smooth body w/resi
    Possibly TPS. If you have fuel and spark I would assume you have air. That's the holy trinity so I would bet on electrical. TPS possibly. Falty TPS the truck will start and immediately die or crank and not start at all. No crank nothing would be a completely different animal.
  4. May 6, 2020 at 5:12 AM
    Timshane 77
    Tim
    1999 Tacoma SR5
    So would throttle position sensor make it seem like it had no compression or had jumped time?
  5. May 6, 2020 at 5:37 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    A bad TPS should trip a code on the 3.4 it will still start and run
    Sounds like crank pulley sheared the key way and is spinning
    A broken timing chain most often jams and you just get a groan
    Did you hear any strange sounds when it happened ??
    ****Have any codes tripped that will point you in the correct direction ???
    With the 2.7pulling the valve cover is the only way to peek at the timing chain
    Tacoma-toy, j4roe and cruiserguy like this.
  6. May 6, 2020 at 5:41 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Remove the air filter hit the intake with a shot of carb cleaner see if it fires then start looking.
  7. May 6, 2020 at 7:37 AM
    Timshane 77
    Tim
    1999 Tacoma SR5
    Ok. I pulled the valve cover off and the chain is still intact. Is there a way I can tell if it has jumped time. I guess these engines don't break very often because I can't find anything with details online. I didn't hear any strange noises when it quit running. I pulled the number one plug out and it's definitely getting gas. It smelled of gas really strongly.
    cruiserguy likes this.
  8. May 6, 2020 at 8:05 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    So you have gas, no spark then?
    Timing chain rarely has issues in these.
    So you hold key over and it cranks but doesn't fire up? You get no firing? You have gas so ECU is getting signal from crank and cam sensors.
    While it's cranking over does it sound the same as it did when cranking over before? Before it started up? No different sounds for the cranking part?
  9. May 6, 2020 at 9:01 AM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    KISS!!!! Keep it simple brah. You didn't jump time. What do you mean make it seem like no compression? What gives you the impression you have no compression? KEEP IT SIMPLE, STUPID. Overnight you didn't blow piston rings. Overnight you didn't jump time. You have air, fuel and spark. If you have the holy trinity and it won't start it's ELECTRICAL. The only difference between gasoline and diesel engines. They're mechanical and we are not.
  10. May 6, 2020 at 9:06 AM
    Tacoma-toy
    Tacoma-toy Master Auto/ASE Tech
    Danny
    Michigan
    2017 Tacom Pro cement
    rock lights, BFG's, Overhead console USB port
    If it's flooded with fuel it can cause low compression by washing the oil off the cylinder walls, smell the oil and if you smell gas, change it. put in a new set of spark plugs then when you try starting it hold the gas pedal to the floor until it fires then let up.
  11. May 6, 2020 at 9:09 AM
    j4roe
    Joe
    Phx, AZ
    1st Gen
    Partially incorrect sir. Ask me how I know. Go to my LT build thread and read through last two weeks worth of issues I've had. I just had a TPS go out and it wasn't throwing a code. At first you could start truck and it would idle and run normally until throttle input exceeded 30% then all of sudden it feels like you're in 15th gear. No response from throttle input. This is the classic TPS scenario. I've experienced that twice now in 12 years. One day later before my new part arrived the truck would crank, start and then immediately die. All due to the falty TPS. The ecu needs information from the TPS among a few other sensors to start. Crank, cam angle, coolant temp, air intake temp, MAF. You can test TPS on the truck with a MULTI-METER.
    One other place might be MAF but I doubt it unless you just cleaned it. An OBD2 blutooth reader is suggested because you will be able to see all of these metrics real time. First you need to get the engine to run though. OBD2 reader would be able to show you the TPS is working correctly though WITHOUT the engine running. If you press gas pedal and TPS value does not increase or is jumping around you know it's bad.
  12. May 6, 2020 at 1:50 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just what year I can unplug my TPS and drive the Truck just fine maybe mine is a fluke
  13. May 6, 2020 at 1:53 PM
    Timshane 77
    Tim
    1999 Tacoma SR5
    No. It does not sound the same as it did before. It turns over really fast. That's why I say it seems like it has no compression. I mentioned this in the original post.
    Wyoming09 likes this.
  14. May 6, 2020 at 1:56 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    We can only go by the information you give to us.
    Have you pulled any codes??
  15. May 6, 2020 at 5:50 PM
    cruiserguy
    Elijah
    SEKS
    I'm wondering if you're describing the symptoms of when the bendix of the starter is not engaging the ring gear or flywheel for whatever reason and just spins fast. And the engine wouldn't be turning over.
    This doesn't sound like what's going on right?
  16. May 7, 2020 at 12:34 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    a bad starter drive to me sounds nothing like a cranking engine .
    Yet it very well might to some people.
    Easy enough to check with a helper to watch the crank pulley
    cruiserguy[QUOTED] likes this.
  17. May 7, 2020 at 4:50 AM
    cruiserguy
    Elijah
    SEKS
    Just throwing ideas out there. Pretty different sounds to me as well, but I could see my brother describing something like that lol
  18. May 7, 2020 at 5:48 AM
    Timshane 77
    Tim
    1999 Tacoma SR5
    No.its not the starter. I don't have a code reader. There was no check engine light. I guess I could go buy a cheap one. I borrowed a compression gauge. It's reading 110 on #1 90 on#2 and #3 and 60 on #4. I just don't understand how it can be running fine and then this. Only thing that seems to make sense would be jumping time. That's why I keep mentioning that. I am no real mechanic, I just like to fix things myself. I'm gonna go out and pick up a Haynes or Chilton manual today. Thanks for all the suggestions. Luckily I have another truck to drive I may just tear this down and do a timing set and have the head checked.
  19. May 7, 2020 at 5:58 AM
    Theekillerbee
    Theekillerbee Member
    2003 Taco
    Your compression is no bueno. 110 is on the low end of keeping your engine running. 90 is borderline of even firing. 60 is really bad and is not enough compression to fire. That is likely why you are spinning your crank so fast. I don't recall factory specs, but it's likely around 140 PSI. Can't say exactly what happened, maybe blown head gasket, bad rings, bad valves, cracked head.....etc. Gonna need to tear it down. You could do a leak down test to use to try to narrow it down, but either way, it needs a rebuild.
  20. May 7, 2020 at 6:20 AM
    Timshane 77
    Tim
    1999 Tacoma SR5
    How do I do a leak down test
