99 Tacoma front axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thelumberwagon, Jun 1, 2011.
  1. Jun 1, 2011 at 5:24 AM
    Thelumberwagon
    Thelumberwagon [OP] Well-Known Member
    I've got a 99 TRD that I have some front axle questions about. The CV boots are shot and I am going to replace both axles as well as the wheel bearings while I'm at it.
    I've noticed some slop where the axles go into the Diff. I'm having a hard time locating a schematic or diagram of this and my Chilton manual doesn't break it down like I think it should.
    My question to you guys is: Will replacing the axles eliminate this slop or are there bearings in there that I need to replace as well? I looked at a diff rebuild kit but I don't think I need to go that extreme. If there are bearings, where can I find just those and not the complete diff rebuild kit?
    Thanks.
  2. Jun 1, 2011 at 8:06 AM
    Thelumberwagon
    Looks like I've found what is listed at "outer differential bearing, Front" and "front axle shaft bearing".
    What is the difference in these?
