99 Tacoma Help!!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by nvinson, Nov 30, 2014.
  1. Nov 30, 2014 at 6:28 PM
    nvinson
    nvinson [OP] New Member
    Neal
    Texas
    1999 Tacoma PreRunner
    Ok guys. Have 99 Tacoma PreRunner, 6 cylinder. Several months ago it was giving a code that indicated that an O2 sensor was bad. Can't remember which one it was. My son actually drives the truck, was in town for the Thanksgiving holidays. I decided to change both sensors since they were really easy to get to. The CEL was actually not on anymore but the truck was really running bad at anything over half throttle. I mean it would LAY DOWN on you if you got on it hard. So... changed both sensors, no change. Have since changed the mass air flow sensor, fuel filter, new catalytic converter, new plugs and wires, new coil packs, and new air filter. All to no avail. Mechanic was going to try and check fuel pressure but couldn't find a place to do it. O2 sensors were Bosch. Read where they are not liked very well by Toyotas but it was running bad prior to the change. Was thinking that it might be the fuel pump. Any similar problems??? Please help!!!!
  2. Nov 30, 2014 at 6:58 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    clean the MAF sensor first then test it with a meter, if that's not it test the fuel pressure a lot of times a week fuel pressure will cause a vehicle to run bad and not throw a code
  3. Dec 1, 2014 at 9:16 AM
    nvinson
    Neal
    Texas
    Brand new MAF sensor.
  4. Dec 1, 2014 at 9:27 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    all that and you haven't replaced the cheapest and easiest part yet, under the drivers seat on the frame rail is the fuel filter, replace it.
    even if that's not it, it is something you do for routine maint.
  5. Dec 1, 2014 at 2:07 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yeah he got it changed...
  6. Dec 1, 2014 at 4:17 PM
    keakar
    karl
    louisiana
    ok, I missed that :eek:
  7. Dec 1, 2014 at 4:21 PM
    Clearwater Bill
    Billy
    Largo Florida
    +1. Sounds like a lot of money went out the door 'guessing'.
    You need codes pulled. There can be code(s) pending that are readable, but have not had enough keycycles to set the CEL yet.
    And why did the previous CEL extinguish? These things don't just heal themselves..........
  8. Dec 2, 2014 at 6:32 PM
    nvinson
    Neal
    Texas
    Yeah, but even with the guessing, a lot of those things were needed. Guess I'll end up at a Yota dealership and let them diagnose it.
  9. Dec 2, 2014 at 9:01 PM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    Like BPS99 states, get codes pulled. Any auto chain will do it for free if you don't have a scan tool.
    All that work done, but have you cleaned the throttle body? If the valve is gummed up it can be starving the system of O2. Maybe it is not opening properly. Pull the air system and watch it as someone presses down on the gas pedal. Clean it - just be sure to use throttle body cleaner.
    I have seen posts where people get some gel like stuff and proceed to spray an entire can at it. Bahh. Toothbrush, clean rag, $9 bottle of cleaner and use it sparingly. Will shine it up nice and leave you enough fluid to do it about 37x more.
  10. Dec 12, 2014 at 1:32 PM
    nvinson
    Neal
    Texas
    Ok, it was the crankshaft position sensor.
  11. Dec 12, 2014 at 1:35 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ^^ Right on. Congrats!
  12. Dec 12, 2014 at 8:27 PM
    97TacoNM
    Jim
    NM
    Glad you got it. The FSM for Toyota's (certainly for my Camry) list that as one of the sensors that is involved in getting the mixture right, so idle issue, accell issues, that is one to test (ECT, MAF, TPS, Injectors, Coil, etc.)
