99' Tacoma knocking sound from engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by SirBunsy, Jun 7, 2017.
  1. Jun 7, 2017 at 6:11 PM
    SirBunsy
    SirBunsy [OP] New Member
    Eric
    1999 Toyota Tacoma 2d Prerunner
    Hello world,
    I was driving for 30 minutes and I got this knocking noise from my engine, I pulled over right away. My truck shut off. I popped open the hood and the coolant was overflowing. The temperature gauge was in the middle. It wouldn't turn back on. Now it turns back on but this knocking noise continues. My father suspects it's either a head gasket or thermostat.
    Any second opinions on why this is happening? This is my first vehicle.
    I know more about software engineering and queer theory than I know about cars.
    Truck specs:
    1999 Toyota Tacoma 2dr Prerunner Extended Cab SB
    170,256 Miles
    2.7L I4
  2. Jun 7, 2017 at 6:16 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Welcome! You probably are going to need a motor!
  3. Jun 8, 2017 at 12:37 PM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Do not crank that motor again. Is your Check Engine Light on and/or was it flashing when that motor is running in the video above? There is no way that is a thermostat. You have a severe problem. Pull the plugs and see if you can put a long screw driver or long wooden dowel down each cylinder. Turn the block slowly with a wrench (clockwise) and make sure pistons 1 & 4 go up and down at the same time (same with 2&3). Have you ever adjusted your valves? Check clearances on them. Check engine oil, is there any metal shavings there? How much coolant did it puke out? I see no way you don't have to tear that cylinder head off and see what your dealing with along with pulling the motor to look closely at the bottom end (or drop the pan by lowering the differential) especially looking at the crank shaft, rods, wrist pins, balance shafts, etc.
  4. Jun 8, 2017 at 12:42 PM
    GA-3RZFE
    Take a look at your exhaust manifold (passenger side) if there is a HUGE hole it it, it could make a sound similar, but i'm still suspect that you broke a valve off or lost a rod.
  5. Jun 8, 2017 at 7:41 PM
    Glamisman
    Glamisman Well-Known Member
    kind of odd for a toyota 4 cyl to go out like that... tell us how much oil is showing on the dipstick.
  6. Jun 8, 2017 at 7:50 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    ^this.. I have a feeling it was run out of oil.
    I had a buddy throw a rod in a 22re years back and it sounded kinda like that but even worse. But that was a 270k motor that had been knocking for a few months
  7. Jun 8, 2017 at 7:54 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
  8. Jun 9, 2017 at 12:10 PM
    Glamisman
    are going to fix her or sell her?
  9. Jun 9, 2017 at 1:33 PM
    1stevertaco
    1stevertaco Well-Known Member
    atlanta
    2000 taco 4x4
    sway bar end links
    Check out your exhaust manifold. If it's cast, I bet it's cracked.
    You can do a compression test to see if any valves are broken
  10. Jun 9, 2017 at 2:39 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    that aint no exhaust leak boys. this thing sounds like its life is over.
