'99 Tacoma Lost All Keys
Discussion in '1st Gen. Tacomas (1995-2004)' started by robicano22, Aug 20, 2023.
  1. Aug 20, 2023 at 7:20 PM
    robicano22
    robicano22 [OP] Member
    1999 Tacoma, I live in México. For now I just want to be able to use the truck. What are my options for disassembling the ignition and getting the thing started?
    After that, what do I need to order from Rock Auto for the ignition, doors, and fuel door?
    Thanks in advance. Use of the truck is priority but obviously want to get it back to full function eventually.
  2. Aug 20, 2023 at 7:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You can take the ignition switch off the back of the key thing. Gott take the panel under the steering wheel off. But then you still have the steering lock problem, I don't know how you'll deal with that.
  3. Aug 20, 2023 at 8:13 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Two screws hold the switch on back of the key cylinder...
    pop that loose and any flat blade can twist that and start it...
    easy peasy......
    BUT BUT your steer column is still locked......
    If you lost the key its gonna be a pain in the ass to change the cylinder out...
    if you cant put the key in the run position.....all that wont seperate from the column.....
    only way to get a part is to drill it out......there's videos and threads on how to do this.....toyotas.....
    When you buy one of these trucks......you never use the master key or one that came with it........theory is your gonna have this truck so long.....key is gonna flat wear out eventually and need to cut another from original master.....
    If you have a boat and dont have a fire extinguisher on it.....you just deserve what u get.....
    Williston likes this.
  4. Aug 20, 2023 at 11:59 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Any lock smiths any place close to you?
    Pop the right door lock cylinder out and have a key made option one.
    #2 It takes two people to drill out the pin that holds the lock cylinder in. One to drill the other to hold the pin from spinning the pin spins and defeats being able to drill. Then have a new key made.
    #3 go full gangster just break everything and use the electrical ignition switch.
  5. Aug 21, 2023 at 11:09 AM
    O'Silver_Taco
    MD
    Yeah I buy all the parts and bite the bullet...
    get someone with auto mechanic experience to help...
    in my part of the country the mexican mechanics are the best...
  6. Aug 21, 2023 at 10:04 PM
    robicano22
    anyone know how i get around this?? there's lots of videos on drilling out a ignition lock cylinder but i can't seem to find anything (toyota or not) that talks about getting around the steering lock afterwards...
  7. Aug 22, 2023 at 1:20 AM
    Bivouac
    That is the thing to unlock the steering 2 choices get the lock cylinder out allowing you access to remove the lock.
    Destroy every thing to get to the steering lock.
    Once you see what your dealing with it is simple.
    You don`t know anyone that has ever done this near where you live.
  8. Aug 22, 2023 at 7:22 AM
    robicano22
    Oh ok so I misunderstood Silver Taco's post. If I remove the ignition lock cylinder I will be able to both start the truck and steer the truck, correct?
  9. Aug 22, 2023 at 9:17 AM
    Bivouac
    Told him how to fix his lost key problem.
    If he wanted to steal the truck that is another forum!
    Why would anyone need help to steal a Truck?
    Taco critter likes this.
  10. Aug 22, 2023 at 10:07 AM
    robicano22
    Don't need to steal it when i already own it :thumbsup:
  11. Aug 22, 2023 at 2:34 PM
    O'Silver_Taco
    MD
    100yrs ago....I used to unload rail cars....
    sometimes the loaders would not stash the keys in the tri-levels right....
    SO two ways to move it ......one is to snap the steering wheel and bust the lock...
    yeah they're not very tough.....really just show....
    The other was to hook a chain to a semi and drag it across the parking lot........
    third way is to roll couple feet....and have someone on each fender....bounce front and repoint it.....
    Bivouac likes this.
  12. Aug 22, 2023 at 8:16 PM
    16withaprerunner
    16withaprerunner PERFECT POISE AZ
    Nate
    Peoria, AZ
    White 2k PreRunner & Bagged 93 SingleCab
    PR-Basic B*tch SC- Bagged + Bodied tuckin 22s
    no way you actually did that, right? I mean that's like some Vin Diesel stuff right there... Except he could do it by himself
  13. Aug 23, 2023 at 12:27 PM
    O'Silver_Taco
    MD
    Yeah the train cars keep coming in every day......dont stop for no one....
    I can remember when mt St. helens blew up......the cars keep coming...
    .....covered in volcano ash..........
    the worst was when the bums would break into the Eldorado's and Seville's and live in them for about a month.......stunk to high hell.....
  14. Aug 23, 2023 at 7:16 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    You could order a key made by Toyota. These trucks don't have anti-theft chips in the keys so they are cheap to make. I think all you have to do is provide your VIN and they can look up the code to make a new key without a copy.
  15. Aug 23, 2023 at 8:36 PM
    rkilpa
    rkilpa Active Member
    Ron
    2001 Tacoma SR5 Double Cab
    As Kiloyard stated, go to a Toyota dealership parts department with proof of ownership (title and ID) and they can cut a key off a keycode decoded by the VIN. As long as you have the original cylinders...
  16. Aug 24, 2023 at 7:49 AM
    Glamisman
    Glamisman Well-Known Member
    Disconnect the battery and wait 10 minutes* then take the steering wheel off, then take covers off of the housing behind the steering wheel. You will see where the steering lock housing is attached to the steering column. On the left side you will see where the sheer bolts that hold the lock housing to the column are. With a small sharp chisel strike the edge of the sheer bolt shoulder in a counterclockwise direction. The bolt will loosen. Once that bolt is loose the other one should loosen. You can then take the entire housing off and then decide if you want to replace the whole thing with new lock cylinder or ?
    *people have been killed when banging on the steering column/playing with the steering wheel on air bag equipped cars. Ignorance while repairing cars can kill you https://www.jacksonville.com/story/...ator-ruptures-during-car-repair/15766381007/#
    There are other stories.
