99 Tacoma Lug Nut Problems
Discussion in 'Wheels & Tires' started by Anthony250, Feb 27, 2011.
  1. Feb 27, 2011 at 3:28 PM
    Anthony250
    Anthony250 [OP] Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Well my tacoma has right now the Trd Sport Rims off a newer truck, and i just bought some American Racing Baja Rims Same lug pattern and the lug nuts off the trd rims obviously dont fit. The problem is i need a lug nut that has the shank really slim to fit in the holes. Or do i need longer studs ?
    Thanks
  2. Feb 27, 2011 at 5:22 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
  3. Feb 27, 2011 at 6:45 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thanks but i found out i bought Hubcentric wheels :mad:, so they are going up for sale for what i got them for and finding a similar set.
  4. Feb 27, 2011 at 6:46 PM
    KPT
    09 Prerunner
    What's wrong with hubcentric wheels?
    Unless they are hub-centric for a chevy (same bolt pattern as tacomas but smaller hub bore).
    If that's the case, a shop can bore them out for you for cheap...
  5. Feb 27, 2011 at 7:01 PM
    Anthony250
    Anthony
    San Gabriel Ca
    can i make them work? I would love to becuase i got the wheels for 150 with tires low tread but still something, they have a 3 inch center bore and still looks like the studs would be short even with the bored out.
  6. Feb 27, 2011 at 7:03 PM
    KPT
    09 Prerunner
    Yep a shop will be able to bore them out....Tacoma's hub bore is 106mm.
    Tacomas have really short wheel studs to begin with. You just need extended thread (E/T) lug nuts. They have some on the page I posted above.
  7. Feb 27, 2011 at 7:09 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Hmm i want to but switching studs would be the only pain , i just got back from looking at some same exact rims with goodyear td tires with good tread off a toyota landcruiser for $380 and thinking about it , cuase i can sell the ones i got and get the ones off the land cruiser and they mount up no problem i think
    and how much for a bore all four wheels ? you estimate
  8. Feb 27, 2011 at 7:11 PM
    KPT
    09 Prerunner
    Won't need to replace the studs. The lugs nuts are designed to grab more thread with their threaded shank.
  9. Feb 27, 2011 at 7:20 PM
    Anthony250
    Anthony
    San Gabriel Ca
    But i went to pepboys today and some other autoshop to look for long skinny shank lugs and couldnt find any, cause the holes for the studs seem to small for lugs, like they would only accept acorn style and hen you would have to use longer studs, so how much you think to bore all four wheels ? actually can i do this myself i got a router. it already has a line marked at 106 mm
  10. Feb 27, 2011 at 7:24 PM
    KPT
    09 Prerunner
    Not sure how much to bore them out exactly...call around to get some quotes...certainly something you could do yourself.
    I wouldn't think you would find any E/T lugs at a store. I've only ever seen them online.
  11. Feb 27, 2011 at 7:26 PM
    Anthony250
    Anthony
    San Gabriel Ca
    thanks so much Keith , im gonna call around , id hate to resell the wheels and get another set, but its also easier with a lug centric set. do you know what size E/T lugs to get for my tacoma?
  12. Feb 27, 2011 at 7:29 PM
    KPT
    09 Prerunner
    The regular length ones on the Wheelers site will be fine. That's what I'm running.
  13. Feb 27, 2011 at 7:35 PM
    Anthony250
    Anthony
    San Gabriel Ca
    So boring the hub and then getting those lugs , would have enough clearance to grab on the lugs? Hmm not sure still thinking about just selling and getting the wheels i saw with tires today. Already started getting calls on the wheels i just posted up for 200 to see what offers i get.
  14. Feb 27, 2011 at 8:08 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Do all aftermarket wheels that are lug centric , have holes for stock lugs? , the ones on the landcruiser i saw today looked like they used oem lugs
  15. Feb 28, 2011 at 5:39 AM
    KPT
    09 Prerunner
    The holes shouldn't be any different. It's just with non-hubcentric wheels you should use shanked lug nuts so that the wheel is centered on the hub.
