99 Tacoma Manual Transmission whinning
Discussion in '1st Gen. Tacomas (1995-2004)' started by Calebsmith182, Jan 28, 2017.
  1. Jan 28, 2017 at 12:49 PM
    Calebsmith182
    Calebsmith182 [OP] Member
    Caleb
    99 Tacoma (red) 95 Tacoma (green)
    (Red) Nothing crazy, Blisten adjustable 5100 and 31 toyo mt. (Green) Straight piped, 31 general grabber
    250 km into a 500km road trip I started to smell transmission fluid but didn't think anything of it because it was not that strong. Appon arrival i noticed a small puddle of tranny fluid underneath my truck and my transmission now has a faint whine in 4th and 5th. I'm 8 hours away from home, what are the chances of me making it home without a bearing seizing if I stop the leakage replace the last fluid.
  2. Jan 28, 2017 at 4:05 PM
    MR2
    MR2 Master of none
    Massillon, Ohio
    The only OLD TACO in Ohio
    BUT WAIT THERE'S MORE!
    Well that is pretty vague. Where are you currently and where are you going.
    Do you know how to check all of your fluids? The manual trans fluid doesn't have a dipstick and won't be easy to check uness you can roll around on the ground and have some tools.
  3. Jan 28, 2017 at 4:45 PM
    Calebsmith182
    Caleb
    Yeah I have tools. Rolled around in the wind and rain and dumped the tranny fluid out roadkill style . I got royal purple synchromax tranny fluid and pumped about 2.1 quarts in (thankfully I was close to a Canadian tire). Noise seems to have quited down but is still present. I'm currently in lethbridge A.B and I'm driving home to Radium hot springs B.C. through the crowsnest mountain pass so hopefully she makes er!
    MR2 likes this.
  4. Jan 28, 2017 at 4:56 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Might be a regional dialect thing but do you mean gear oil?
    Can you tell where it is leaking from? The rear output seal is the usual suspect on the 1st gen MT. Leaks down into the adapter for the transfer case. Best short term fix is to keep ensuring the MT is full until you can pull the transfer case and replace the seal.
