99 Tacoma no brakes Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman27, Jul 29, 2015.
  1. Jul 29, 2015 at 10:13 AM
    Tacomaman27
    Tacomaman27 [OP] Active Member
    First time posting on here. Just bought a 99 4wd Tacoma has no brakes at all the pedal goes alway to floor cannot pump up. The previous owner replaced all brake lines an wheel cylinders with no luck fixing the problem so I bought it at a decent price. Any help will be apericated
  2. Jul 29, 2015 at 10:26 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Has the master cylinder been replaced?
  3. Jul 29, 2015 at 10:33 AM
    Tacomaman27
  4. Jul 29, 2015 at 10:39 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    If the previous owner actually replaced the lines, wheel cylinders and front calipers, then all that's left is the master cylinder, and maybe the proportioning valve in the rear. My vote is master cylinder if it's not pressurizing at all.
  5. Jul 29, 2015 at 10:42 AM
    Tacomaman27
    He changed the proporting valve also I forgot to mention An no it's not pressureizing at all
  6. Jul 29, 2015 at 10:46 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    then lines are filled with air or master cylinder is bad.
    disconnect brake lines from master cylinder and pump the pedal as you hold your finger over he hole. if pressure comes out then the lines are just full of air.
    the rear proportioning valve is a bitch to bleed so expect to take extra time n bleeding the rear brakes
  7. Jul 29, 2015 at 10:58 AM
    Tacomaman27
    Ok I will try that this evening after work I'll post an update. Thanks
  8. Jul 31, 2015 at 4:16 PM
    jesse20053
    jesse20053 Member
    1995 toyota tacoma
    2 inch lift and too many new parts to list
    Did you blead the proportion valve? It has to be bleed out to just like the master cylinder and brake calibers.. I fought with mine til someone told me I have to blead the proportion valve in the rear..
  9. Aug 2, 2015 at 1:33 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have only ever tried to bleed the LSPV one time and found out how expensive they are.
    I have changed many hydraulic parts on Toyota`s over the years with out touching the Lspv ever again
    Since some older Toyota`s are on the right newer on the left one just needs to bleed things according .
    Never had problems getting a good pedal feel.
    Another thing most tend to only think of the rubber hoses when they get torn or get a hole as they age they get soft and can blow up like a balloon under pressure.
    Another is dirt in the flare connections or bad bleeder valves it does not take much to allow air in and not have a fluid leak.
  10. Aug 4, 2015 at 5:24 PM
    Tacomaman27
    Just bled the proportion valve an all wheels. Had air in the lines. It's fixed now
  11. Aug 4, 2015 at 6:07 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
