'99 Tacoma pass side rear axle alignment issue after OME Dakar install (fixed)
Discussion in '1st Gen. Tacomas (1995-2004)' started by jonnyozero3, Nov 6, 2016.
  1. Nov 6, 2016 at 11:46 AM
    jonnyozero3
    jonnyozero3 [OP] Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Update: Alignment done again at the shop, came out normal. Looks like it was just a misplaced alignment head by the tech. Nothing to see here...carry on!
    Gents,
    Any ideas what might cause a passenger rear end misalignment after a new suspension all around in a 1st Gen? Didn't think it was possible for one side of a solid axle to get crooked like this.
    Here's the data: http://i.imgur.com/LklsMUi.jpg I had the entire suspension replaced recently, and noticed while going through my paperwork that the rear end now has 1.4 deg camber, 3.0 deg toe with 2.91 deg total toe and a -1.55 deg thrust angle. As you can see, before the leaf replacement the rear axle was almost zero'd out (like I assume it would be, solid rear axle and all...).
    Old suspension:
    - OME 881 / OME N91S
    - Stock leaf springs w/Downey 1.5" AAL and OME N85 shocks
    New Suspension:
    - OME 881 / Bilstein 5100 including Wheelers ~1/4" poly spacer on driver's side
    - OME CS046RA/B Dakar leaf springs (3rd leaf removed) w/Bilstein 5100s and OME GS12 no-lift greasable shackles
    Any clues what could cause that change in the passenger rear end only with the new suspension parts? Or how to fix it?
    Note: the shop did the 100mi re-torque of my new ubolts and did note that one of them required almost a full turn.
    Appreciate any ideas.
  2. Nov 6, 2016 at 12:10 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Possibly an issue with the leaf spring centering pin
    jonnyozero3[OP] likes this.
  3. Nov 7, 2016 at 6:45 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Thanks, I will get that checked first.
    Still curious how even a bent centering pin can make only one wheel go "crooked". Not sure I understand how a single wheel has a movement point like that on a solid axle. Huh.
  4. Nov 7, 2016 at 7:07 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This is a long shot, but the axle housing on my old '84 crawler had 2 holes
    in the spring pads (one centered and one offset) for the centering pin head to go into.
    I don't recall if my Tacoma has that or not.
    If it does, it could be that the offset hole was inadvertantly used on one side.
    With the front wheels straight, carefully check your wheel base on both sides
    (distance from center of front hub to center of rear hub). They should be identical.
  5. Nov 7, 2016 at 7:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    The right side is definitely not seated right with all of that positive camber and toe. The left side is seated correctly where the right side is actually forward of the axle centerline in relation to the centering pin.
    My guess: the centering pin is forward of the centering hole.
  6. Nov 7, 2016 at 8:15 AM
    tan4x4
    Rick
    Folsom, CA
    Perhaps the centering pin head didn't even seat into a hole at all (ie - INSTALLER ERROR )
    US Marine likes this.
  7. Nov 7, 2016 at 10:01 AM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    I am hoping it was just a measurement issue with the alignment tool doo-dad. We will see as soon as I can get back over to the shop. Appreciate the opinions, I will ask them to check the center pin if the measurement comes out the same.
    Happy to have the "lifetime alignment" package with Firestone right now...
  8. Nov 7, 2016 at 10:14 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    ^ ....... This !!
  9. Nov 15, 2016 at 2:36 PM
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    frenchee likes this.
