99 Tacoma Prerunner SR5 TRD gear ratio???
Discussion in '4 Cylinder' started by DrunkenDangler, Dec 27, 2011.
  1. Dec 27, 2011 at 1:44 PM
    DrunkenDangler
    DrunkenDangler [OP] Well-Known Member
    AL
    2005 5 lug access cab
    fat bob lift
    what kind of rearend comes in a 4 cyl 99 Tacoma Prerunner SR5 TRD with a auto tranny?
  2. Jan 5, 2012 at 10:23 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    Search "1st gen axle codes."
    It's a number on the data plate on the door jam.
    It contains all the info about the rear end from the factory.
    There's a few threads on here about how to figure it out.
    HOWEVER! YOU'RE IN LUCK!
    BECAUSE I HAPPEN TO HAVE A TOTALLED 99 TACOMA SR5 PRERUNNER 4 CYLINDER AUTOMATIC IN MY YARD!
    And if it helps, the totalled 99 Tacoma SR5 Prerunner 4 cylinder automatic in my yard has a Toyota 8" Standard rear axle and a 4.30 third.
    TRD usually means you have a locker, but I think on the 1st gens, a 4 Cylinder Auto with the TRD package didn't include the rear locker. Just the other junk.
    :cheers:
