99 tacoma problems shifting until engin warm ?? Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99 gold Tacoma, Jun 24, 2021.
  1. Jun 24, 2021 at 5:57 AM
    99 gold Tacoma
    99 gold Tacoma [OP] Member
    99 tacoma
    Got a 99 tacoma 5 lug with 2.4 auto. In the mornings, or when it sits, its hard to shift. Engin will rev when first starting out, then shift into second , rev until warm then shift into third. Once up to temp, seems to shift good. I have let it warm up for about 10 min before driving, and does fine
  2. Jun 24, 2021 at 6:00 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    When was the last tranny fluid change/how many miles on the current fluid?
    I had a '99 prerunner auto that when this happened the transmission pooped the bed very shortly afterwards. That said, that transmission was rode hard a couple times pulling too much weight & hadn't had a fluid change in way too long.
  3. Jun 24, 2021 at 6:01 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    How’s the fluid level?
    Has the fluid ever been changed? :anonymous:
    Wulf and gsubioguy like this.
  4. Jun 24, 2021 at 8:24 AM
    99 gold Tacoma
    99 tacoma
    Fluid is good, not brown or burnt. Previous owner had Fluid changed at 60k at dealership.
  5. Jun 24, 2021 at 8:52 AM
    gsubioguy
    Evan
    Maine
    '21 TRD OR
    How many miles are on the truck now?
  6. Jun 24, 2021 at 9:43 AM
    99 gold Tacoma
    99 tacoma
    Truck has 123k
  7. Jun 24, 2021 at 9:46 AM
    99 gold Tacoma
    99 tacoma
    No check engine light, doesn't leak a drop of anything...
  8. Jun 24, 2021 at 10:01 AM
    b8hickman
    b8hickman Member
    Bill
    2000 Toyota Tacoma. Had 17yrs with 145,000 miles
    lift, bumper, warn winch and 285 tires.
    I have a 2000 Tacoma with 145000 miles. Mine used to do that. I changed the transmission fluid and had it flushed out, still did it. Then changed it the fluid to Royal purple and it still did it. After many years of this I had a mechanic tell me to go back with the recommended transmission fluid from Toyota and to put transmission additive in it. It's been several years but I think he told me to use trans X. After I did that the truck went back to shifting normal.
  9. Jun 24, 2021 at 3:24 PM
    99 gold Tacoma
    99 tacoma
    Are you saying you put in a new transmission?
  10. Jun 24, 2021 at 6:22 PM
    b8hickman
    b8hickman Member
    Bill
    No, just changed the transmission fluid with Toyota spec transmission fluid and put in that additive
  11. Jun 25, 2021 at 11:25 PM
    Crstacos
    Crstacos Member
    chr
    2002 tacoma
    none
    Mine does it too 2002 with the a340f tranny with 370k it likes a minimum temp before it wants to shift into 3rd this only happens when its below freezing and not warmed up
