99 Tacoma tail lights not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phil4x4, Feb 25, 2017.
  1. Feb 25, 2017 at 3:41 PM
    Phil4x4
    Phil4x4 [OP] New Member
    Need a little help. First off I am not that mechanical minded so please bear with me. My tail lights quit working. I have headlights brake lights and turn signals but no tail lights. I have checked the fuse under hood its good. when I turn lights on I can hear relay click so that's working. I also checked bulbs their ok. Someone said it could be my multi function switch. The switch controls headlights and turn signals but could it be faulty not letting my tail lights work properly? Any thoughts to help would be most appreciated... thanks
  2. Feb 25, 2017 at 4:16 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Do you have a trailer harness? If so it could be causing a short/open. Get a volt meter and start tracing the power.
  3. Feb 25, 2017 at 4:19 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    I had the same issue. It was the trailer harness plus a gummed up connection at the pig tail behind the light itself. The connection gets messed up everytime I'm off-road.
  4. Feb 25, 2017 at 4:19 PM
    Phil4x4
    Thanks but I don't have a trailer harness
  5. Feb 25, 2017 at 4:20 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    do your dash lights work? If not, check the fuses. Same fuse runs taillights and dash lights, I believe
  6. Feb 25, 2017 at 5:22 PM
    Phil4x4
    My dash lights are working
  7. Feb 25, 2017 at 8:00 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    This is gonna sound really simple, but have you tried new bulbs in the tail lights? Or a circuit tester to be sure you are not getting any power back to the sockets? Yes, it's a long shot that both could have burned out at the same time, but, you never know...
  8. Feb 26, 2017 at 9:52 AM
    Phil4x4
    I have replaced both bulbs. I have not tried a circuit tester.
