'99 Tacoma turn signal issue
Discussion in 'Technical Chat' started by rathbone, Jan 26, 2013.
  1. Jan 26, 2013 at 1:04 PM
    rathbone
    rathbone [OP] New Member
    Doug
    Colorado
    99 Tacoma 4WD 3.4ltr
    I have a 3.4 V6 4X4 Xtracab, recently the turn signal lever has started malfunctioning. When I lift it for right turn the signal activates at the halfway point but when it clicks into position the signal light (dash and front and back lights) goes out and there is a very fast clicking sound. The left position works fine and if I hold the in the halfway position the right signal works. Sometimes I can pull in or push out the signal level while I lift and the signal will work fine. What should I expect to have to replace to fix the problem? thanks
  2. Jan 27, 2013 at 2:12 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I would start by replacing the switch.
    10 or 20 bucks at the wreckers.
