99 tacoma v6 overheating
Discussion in '1st Gen. Tacomas (1995-2004)' started by Foresty4x4, Sep 13, 2020.
  1. Sep 14, 2020 at 10:32 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol
    JudoJohn likes this.
  2. Sep 14, 2020 at 10:41 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Sorry you can’t read.
    Your anecdote bad, mine good? Really? That’s how you read that?
    how about one anecdote says one thing, the other one, says a different thing.
    the manufacturer recommends one thing, so I use that one thing.
    not that difficult man.
  3. Sep 14, 2020 at 10:46 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Good question, I bet Toyota chemical engineers have the answer for you.
    All I know is I use what they recommend and don’t seem to have issues. By all means, put water in you truck for all I care. That will “work” for a period too.
    oh I’m sorry I didn’t know I had to spell it out for you.
  4. Sep 14, 2020 at 10:50 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I prefer yellow!
    But VW has this dope Purple one now. BMW uses blue raspberry, doesn't taste as good as it looks.
    Bottom line, as long as you don't mix em, green, yellow, red, pink.... they all work fine, the only difference is the interval at which you change them out
    Das it mang and Dalandser like this.
  5. Sep 14, 2020 at 11:00 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The answer is Toyota had to go a certain route and went with it - the very same way Detroit engineers chose another route and went with it. There's no magical effect a coolant has on materials which are used for engines spec'd for both.
    The use of the 22re anecdote didn't indicate it was shedding light to how anecdotes may serve both arguments - the tone of the phrasing much more clearly gave the impression you thought you were right.
    jbrandt likes this.
  6. Sep 14, 2020 at 11:07 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Ya. Hence the immediate post I made after. Talking about each being an anecdote.
    However, with that being said, one anecdote complies with Toyota manufacturer recommendations. The other does not.
  7. Sep 14, 2020 at 11:13 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You're entitled to your opinion, you're not really making a convincing argument with people having personal experience and reputable sources not agreeing with you.
    Speedytech7 likes this.
  8. Sep 14, 2020 at 11:13 AM
    Speedytech7
    And absolutely none of this talk of coolant types has anything to do with this man's truck getting slightly warm (a complete non issue). :p
  9. Sep 14, 2020 at 11:16 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I have to agree. I would suspect head gasket leaking. I had a car that was overheating and that was the cause. It was leaking slightly enough into the cylinder, and not mixing oil and coolant, which is a tell tale sign. Get an oil analysis done. That will tell for sure.
    Speedytech7[QUOTED] likes this.
  10. Sep 14, 2020 at 11:19 AM
    Speedytech7
    My 4 banger did that actually, but it would get pretty hot climbing a grade, about 225 or more without even being in the gas much. Ended up having a cracked head. The 4 banger is known to run cooler though so it was more of a tip off. I've seen the 5VZ run at 210 when in perfect condition. Part of the reason the factory temp gauge is deadened in the center. 160-220 approx.
  11. Sep 14, 2020 at 11:30 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    It's as if the Toyota engineers are being put on a fairly high pedestal here - almost god-like.
    Yes, Toyota engineers are smart, and know what they are doing (if we ignore their lower balljoint design). It's why we all drive them and are passionate about them.
    That said, certain things, like the exact brand and type of coolant they recommend in all likelihood are NOT engineering decisions, but management/marketing ones. Everyone likes to play off whatever coolant as being "special" so that people will come back to the dealer and buy it.
    But back to the OP's original question. As I said before, 210 doesn't seem all that hot. especially if you're not getting warning lights.
  12. Sep 14, 2020 at 11:39 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    :rofl:
  13. Sep 14, 2020 at 11:40 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Damn, the irony though...
  14. Sep 14, 2020 at 11:43 AM
    jbrandt
    Justin
    I notice you have a non OEM drive shaft\upper control arms.
    I thought the Toyota engineers knew best
    irony squared
  15. Sep 14, 2020 at 11:49 AM
    #35
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You're kind of digging yourself into a hole here.
    Anyway OP, 210 is at the upper end of the spectrum of normal operating temp and moving the jiggle valve to the 6 o'clock position would most likely help if it's not already there - I've had temps in that area at idle with mine prior to replacing everything in my engine bay including the radiator and now get 184 at idle but with an all aluminum (not OEM) radiator. Let us know if that helps or if your jiggle valve is at 6 o'clock already.
    jbrandt and Speedytech7 like this.
  16. Sep 14, 2020 at 11:56 AM
    #36
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    So I guess your argument from personal experience is a valid one
  17. Sep 14, 2020 at 12:03 PM
    #37
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Oh you sure got me there!!
  18. Sep 14, 2020 at 12:58 PM
    #38
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    http://prestone.com/products?detail=AF6200
    So why does prestone make this proper coolant that they recommend for Toyota
    Edit: as opposed to their green stuff for other vehicles?
  19. Sep 14, 2020 at 1:04 PM
    #39
    Speedytech7
    You need to let go, it's okay.
    They make one that safely mixes with Toyota Red and another that mixes with Toyota Pink because they're (say it with me) SAFE TO MIX. If you've already gone to the effort of flushing the original red or pink out theres no reason to continue with them, they make other coolants that are not SAFE TO MIX (you getting that part ?) that work absolutely fine in our vehicles and have all of the same anti corrosion properties. If I was prestone I'd make the safe to mix ones too cause I can charge more for them on the basis of propriety and then I have something that can be used for people just topping off or changing one component or whatever, Zerex does it too. There's only one major coolant that shouldn't be put in anything that doesn't specifically call for it and that's Dexcool.
    96BlueTacos[QUOTED] and jbrandt like this.
  20. Sep 14, 2020 at 1:31 PM
    #40
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Okay:bowdown:
    Okay, I’ll concede you can do it right with mixing and all that with the proper coolants.. I just assume use the factory coolant and all is good.
    But I digress
    :cheers::bikewheelie:
    Aside from all that thermostat stat should open between 178 and 183. And it shouldn’t really go more than 10 degrees above if the coolant system is working properly, from what I understand. So 193-195 I would call okay. But 210 still seems high to me. But what do I know, I use Toyota red:notsure::wink:
