99 Tacoma won't engage 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by quadman80, Mar 7, 2016.
  1. Mar 7, 2016 at 4:51 PM
    quadman80
    quadman80 [OP] Member
    Green 99 Tacoma
    2.5 inch Toytec lift.
    Hey guys and gals,
    I've got a 99 Tacoma and for some reason my 4 wheel drive won't engage. It's a 5 speed with manual 4 wheel drive lever. No push buttons. When I shift into 4 wheel drive I get no light on the dash and no power to the front tires. I can tell the transfer case is working cause when shifted into 4 low its apparent its in low range. Everything is factory except the small Toytec lift. No manual locking hubs. I've checked all vacuum lines and they appear to be hooked up. I've searched for posts regarding this issue and have come up empty. Any help to point me in the right direction is appreciated. Thank you.
  2. Mar 7, 2016 at 5:14 PM
    5TEWN
    5TEWN Member
    Try to put it in 4 LOW. If it goes in and the light is out, the bulb is burned out. You will be able to tell if it's in 4 low.
    Let me know what happens.
  3. Mar 7, 2016 at 5:19 PM
    quadman80
    Green 99 Tacoma
    It goes into 4 low and all the low range gears work but no power to the front tires
  4. Mar 7, 2016 at 8:19 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Your front diff is still controlled by an electronic actuator at the front diff. It engages when you put it in 4wd as opposed to when you hit a button. So being electronically controlled. you do have the issue of stuff like bad grounds or fuses being the culprit. Look for it first then let us know.
  5. Mar 7, 2016 at 9:00 PM
    quadman80
    Green 99 Tacoma
    Is it common for that actuator to go bad??
  6. Mar 7, 2016 at 9:16 PM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    check your 4x4 module as well, its inside the kick panel on the drivers side. Also check your front driveline (maybe broken joint?)
  7. Mar 7, 2016 at 9:17 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Check your add switch on the top of the t case. If that goes bad it won't work
  8. Mar 7, 2016 at 10:14 PM
    quadman80
    Green 99 Tacoma
    What's the 4x4 module look like? How to I tell if the add switch is bad??
  9. Mar 7, 2016 at 10:19 PM
    anthony250f
    Anthony
    San Diego, CA
    You could supply 12v to the actuator and see if the 4wd then works
  10. May 5, 2016 at 11:02 PM
    yotaman44
    yotaman44 Member
    Tiny
    99 Toyota tacoma sr5
    I'm having the same issue with mine also I have vacuum to the actuator tho an it's shifting in 4wd to trying to narrow it all down.
  11. Feb 5, 2017 at 9:11 PM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    can anyone tell me how and where to identify the electronic actuator at the front differential? My front wheels are not engaging and the 4x4 light is not showing on the dash when I try to engage 4x4. Got stuck yesterday and could not engage the front wheels. Any other possible check suggestions would be appreciated.
  12. Feb 5, 2017 at 9:23 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    There's a tube on the right side of the front differential. It's called an intermediate shaft or jack shaft. The ADD (auto differential disconnect) actuator is on the back of it.
    TacomaJunkie8691 and mikkydee like this.
  13. Feb 11, 2017 at 5:20 AM
    mikkydee
    Doyle
    Florida
    Ok I put truck on jack stands with all four wheels off the ground. When I engaged 4x4 shifter the front shaft was turning but the front wheels weren't engaging. This told me to abandon checking the switches on the transfer case and so I pulled off the ADD indicator switch on the front differential and cleaned it well and tested the continuity with my multimeter, it was ok. Decided to check the vacuum on the ADD before I pulled it and had to drain the front differential since I couldn't find my 10 mm hex wrench to remove the drain plug and fill plug. So I followed the vacuum lines from the ADD to two switches mounted on the driver sidewall near the battery and fuse box. I borrowed a vacuum tester from Autozone and removed the vacuum lines from the switches and pulled a vacuum on the lines to the ADD. Then started the truck and engaged the 4x4 with the truck suspended off all four wheels. Whammo, front wheels engaged! So I removed, cleaned and checked the switch. It would definitely click when I bench tested with some alligator clips connected to a battery. One of the vacuum lines would hold a vacuum to it (the one to the ADD). So I cleaned the terminals good with some electronic cleaner and blew it out with my air hose to dry out the cleaner and blow out any debris. Reattached the plug and vacuum lines and 4x4 engaged perfectly but the dash light did not show 4x4 engaged. Then I remembered unplugging one of the transfer indicator switches on the transfer case in order to remove and check. (I couldn't get a wrench to it so I decided to go a different route). Plugged it back in and 4x4 indicator light came back on.
  14. Jan 3, 2019 at 6:35 PM
    Mike_TW
    Mike_TW New Member
    Black SR5 extcab
    Wanted to thank you all for posting. I used your notes to help me figure out why my 4wd wasn't working after replacing my head gaskets (lost a water jacket @250k). I traced it down to a hose connection at the switches by the battery.
    mikkydee likes this.
