99 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Christservant07, Nov 13, 2016.
  1. Nov 13, 2016 at 4:14 PM
    Christservant07
    Christservant07 [OP] New Member
    Green 99 tacoma 3.4
    I have a 99 tacoma 3.4, when I let it sit more than a few hours it is hard to start. After it starts it runs rough until it warms up. I try to give it gas during this warm up period and it will sputter out. It runs great once it warms up. Any help will be great.
  2. Nov 13, 2016 at 4:20 PM
    MTgirl
    Weesa
    Bob's secret mod lair
  3. Nov 13, 2016 at 4:23 PM
    chaosrob
    chaosrob Well-Known Member
    Do 3.4's have a cold start injector? If so that is where I would look first, sounds like it is dumping fuel
  4. Nov 13, 2016 at 4:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'll guess Coolant Temp Sensor but I could be wrong
    chaosrob likes this.
  5. Nov 14, 2016 at 1:16 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    leaking fuel injectors ?? Brings back memories of Jen and Eric
  6. Nov 14, 2016 at 5:55 AM
    Christservant07
    Green 99 tacoma 3.4
    I have replaced the plugs and wires. I will try the fuel filter next, just because it is easiest. I am not sure if it has a cold start injector. If the filter doesn't work I'll check that next. Thank yall. I will update if I find it.
  7. Nov 14, 2016 at 7:26 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This would be my best guess, since the issue is clearly temp-related.
  8. Nov 14, 2016 at 7:38 AM
    chaosrob
    Well I am not sure on Tacomas as I am new but the Supras from the same era had cold start injectors, and they too are temp related. They are often problematic and will dump fuel at start up and result in the same symptoms as relayed by the op above. Like I said, I am not versed on the 3.4's yet so I could be way off base, just a suggestion
