99 toyota 4runner rear end noise
Discussion in '4Runners' started by wfooffroad, Feb 24, 2013.
  1. Feb 24, 2013 at 12:44 PM
    wfooffroad
    wfooffroad [OP] Member
    North Carolina
    98 4 runner and 91 pickup
    99 4runner rear end make noise when you let off the throttle
  2. Feb 24, 2013 at 12:51 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    could be a number of things, any more info
    where in nc
  3. Feb 24, 2013 at 1:19 PM
    wfooffroad
    North Carolina
    Fairview nc just trying to find out if anyone elses 4runner does this
  4. Feb 24, 2013 at 1:29 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    check your u joints first, its not normal
  5. Feb 24, 2013 at 1:38 PM
    wfooffroad
    North Carolina
    i have they look good. Its like a growl when you let off the gas but its quiet when you have you foot on the gas.
  6. Feb 24, 2013 at 1:51 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    have you checked the pinion bearing, carrier bearing in the d shaft or the gears themselves?
  7. Feb 24, 2013 at 1:56 PM
    wfooffroad
    North Carolina
    no i just checked the uv joints and the carrier bearing they had no play good and tight. is it hard to change the pinion bearing
  8. Feb 24, 2013 at 1:58 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    sorta kinda, i wouldnt do it unless youre 100% confident in your wrenching skills
  9. Feb 24, 2013 at 2:03 PM
    wfooffroad
    North Carolina
    i just checked again u can move the pinion up and down plus side to side i think that might be it. thanks for your help
  10. Feb 24, 2013 at 2:17 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    Yes it should not move like that(it shouldn't move at all). Has the pinion but backed off at all? There shouldn't be that much slop without something coming loose.
  11. Feb 24, 2013 at 2:21 PM
    wfooffroad
    North Carolina
    idk i will take drive shaft out and check. Can the nut being loose cause that
  12. Feb 24, 2013 at 2:33 PM
    Redneck92
    Concord, NC
    Yes, its possible, if it came loose its probably too late to just tighten it up though. Sounds like you gonna need a diff rebuild. Depending on what gear you have might be cheaper to find another third member.
  13. Feb 24, 2013 at 2:41 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
  14. Feb 24, 2013 at 2:58 PM
    Redneck92
    Concord, NC
    I second that, they do good work
  15. Feb 24, 2013 at 3:56 PM
    wfooffroad
    North Carolina
    thank ya'll for your help
  16. Feb 24, 2013 at 8:41 PM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I had a noise in my '01 like what you describe. Iput it on 4 jackstands and crawled under it with an engine stethescope. Once I touched the pinion bearing area with the scope I heard he growl immediately. Needed a pinion bearing. Fortunately Ihad the means to rebuilt the centersection myself. I put all new bearing races and seals in that bad boy. I think it was around $250?, for all the parts if Iremember correctly. But that's been a while ago so I could be off on the parts number.
    At any rate, check the wheel bearings, and work your way in to the center section and possibly U joints.
    Good Luck!
  17. Mar 1, 2013 at 6:33 PM
    wfooffroad
    North Carolina
    thanks for the info new 3rd member it is good now
  18. Mar 1, 2013 at 6:42 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Get it from ecgs?
  19. Mar 1, 2013 at 6:45 PM
    wfooffroad
    North Carolina
    no i got it from craigslist some guy had a wrecked one paid $200
