99 won't start after refuel
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoJon32, Oct 19, 2019.
  1. Oct 19, 2019 at 7:36 AM
    TacoJon32
    TacoJon32 [OP] Member
    Jon
    SE Idaho
    1999 Tacoma 3.4L 5speed
    Boner stock
    Hello all, newbie here with an issue. I filled up my pickup today, and as soon as I finished, truck would not turn over. Just cranking to no avail. I have been known to click a little extra gas, but have never had an issue starting the pickup until today. I have read about the charcoal canister possibly being saturated, as well as the fuel filter being clogged, but where should I start?
  2. Oct 19, 2019 at 7:45 AM
    det107
    det107 Well-Known Member
    What a way to start the day!!
  3. Oct 19, 2019 at 11:31 AM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    Tell me about it, I filled up at 545 this morning to go elk hunting then it happened . I replaced the fuel filter, took the gas cap off and tried to start it, inspected the charcoal canister and hoses (in place, I have not had it tested), and I did not know how to remove the fuel pump relay to test it so I didn't. And I do not hear the fuel pump or relay when I turn the key on, so I hope that helps narrow the issue down for someone who knows about these things. Thanks in advance if anyone can help me out.
  4. Oct 19, 2019 at 11:33 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    isnt there a fuel pump fuse also?
  5. Oct 19, 2019 at 11:34 AM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    Battery?
  6. Oct 19, 2019 at 11:35 AM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    I thought there was, but I could not find one labeled as such. Just the big relay under the steering wheel
  7. Oct 19, 2019 at 11:38 AM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    The battery is new, and turns and even chuckles like it's going to start after I leave it to sit for a few minutes.
  8. Oct 19, 2019 at 11:51 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Topping up is no bueno. Floor it and crank 3 seconds. Stop. Wait 3 seconds, should start now. Recommend new Purge selnoid and NEVER topping up again.
    JC15Taco likes this.
  9. Oct 19, 2019 at 11:54 AM
    Black DOG Lila
    Virginia
    Just realized it's 1999 has no available replacement but Corrola part will work. Just different part #
  10. Oct 19, 2019 at 11:59 AM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    I just gave that a try and still just cranked. Is that more likely than the fuel pump going out? It feels like I have either no power to the fuel pump, or it's just not working at all.
  11. Oct 19, 2019 at 12:04 PM
    Black DOG Lila
    Virginia
    If you did saturate the cannister raw fuel will flood it through EVAP hose.
  12. Oct 19, 2019 at 12:05 PM
    Black DOG Lila
    Virginia
    Are you overdue for timing belt change?
  13. Oct 19, 2019 at 12:16 PM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    No, it was done about 30,000 miles ago. It has a new battery, alternator, fuel filter, fresh oil change, and the starter is only a few years old.
  14. Oct 19, 2019 at 1:08 PM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    Just plugged it in, and it's not throwing any codes, so I am baffled. I've never heard of a fuel pump going out without any symptoms or anything.
  15. Oct 19, 2019 at 1:10 PM
    TacoJon32
    Jon
    SE Idaho
    Boner stock
    Does this mean I have to remove the canister and clean it out, or would I need a new a whole one?
  16. Oct 19, 2019 at 3:05 PM
    Black DOG Lila
    Virginia
    Raw gas flooding was a suggestion to help with diagnosis of no start.EVAP hose from tank would have raw fuel which is easy to check for.
  17. Oct 19, 2019 at 3:47 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Disconnect the line from canister to intake plenum and plug it off. Try it again
    Black DOG Lila likes this.
  18. Oct 19, 2019 at 5:13 PM
    paetersen
    paetersen Well-Known Member
    Use a RUBBER mallet to whack the bottom of the fuel tank in the vicinity of the fuel pump while someone cranks the truck. It is not uncommon for a pump on it's way out to be 'stuck' in a dead spot. A little whacking will free it up with the vibration. It's a very quick test, if you suspect a no-fuel condition. Much like tapping on a bad starter, you know, right on the sticker that says "Do Not Strike With Hammer"
  19. Oct 19, 2019 at 6:20 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Solid suggestion, well said hombre :cool:
    ElTaquitoJr and CS_AR like this.
  20. Oct 20, 2019 at 8:35 AM
    ElTaquitoJr
    ElTaquitoJr Well-Known Member
    01 Tacoma PreRunner 4 cyl
    To add on top of all this, this is exactly how one of the family's car died.
    Stopped at pump, fueled up and no start. Fuel pump was replaced and on it went.
    cruiserguy[QUOTED] likes this.
