99 won't start
Discussion in '4Runners' started by buzzard1992, Apr 11, 2012.
  1. Apr 11, 2012 at 4:59 PM
    buzzard1992
    buzzard1992 [OP] Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    My sister has a 99 4runner and just called and said it won't start. The past couple weeks it's turns over longer than it should before it cranks. I'm headin to go see what's goin on now. Any help would be great
  2. Apr 11, 2012 at 5:18 PM
    buzzard1992
    Alex
    Summerville, SC
  3. Apr 12, 2012 at 2:50 PM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    Starter, Batter, MAF Sensor, Fuel Pump. you got any more info?
  4. Apr 20, 2012 at 8:46 AM
    Bawlzdeep
    Bawlzdeep I'm dropping the hammer
    Jon
    Penn Valley CA
    S/C'd 97 4Runner 5spd
    lift, tires, winch, 5spd swap, dual lockers..
    If it's been turning over a lot before it starts it's probably the fuel pump. As long as the battery is good and it's turning over fast enough. The pumps get weak and this is how they go out. You're NOT gonna hear this pump prime like almost every other car in the world. It doesn't get power until the starting circuit is closed. The pump is right under the rear driver's side seat. They're kind of expensive too.
    Good luck. More info would help.
  5. Apr 22, 2012 at 7:14 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    could be anything, need more details.. getting spark,fuel pressure, etc...
  6. Apr 23, 2012 at 4:09 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Your choice of words here is a bit confusing. 'turns over' and 'cranks' sometimes mean different things to different people.
    When the starter motor engages the flywheel causing the motor to rotate, this is what I call 'cranking'. Then it cranks until the motor fires up. Are you saying that there is a delay from when she turns the key and the starter cranks the motor? If so, then this is a problem with the starter.
    If the starter 'cranks' for a long time, but the motor never fires up, then you have a fuel or ignition or electrical problem.
