9mm ARs
Discussion in 'Guns & Hunting' started by Doughnut Spaghetti, Apr 20, 2017.
  1. Jan 19, 2019 at 1:26 PM
    #81
    Durango95
    Durango95 Well-Known Member
    Great North Woods of Wisconsin
    17 QSTRDOR4x4ACATFTMFW
    IMG_0041.jpg IMG_0040.jpg CMMG, 4" bbl with an SWR Octane 9hd.
  2. Jan 27, 2019 at 2:24 PM
    #82
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I am now a running POF 4.5lb trigger. I am loving the feel and performance.
    Durango95 likes this.
  3. Apr 10, 2019 at 3:21 PM
    #83
    JustJon
    JustJon Well-Known Member
    MI
    18 DCSB OR
    Hey everyone, throwing this question out there to see if anyone else has run into this problem:
    I am having burst/double fire issues and I think some almost out of battery scares:
    build is:
    FM dedicated glock lower
    glock/colt BCG, cmmg pin/spring (broke original)
    Faxon 8.5 barrel
    FM 9mm buffer 6.5oz iirc
    standard carbine spring, did just install a 308 spring and try again.
    LWRC trigger
    Thoughts? has anyone here encountered this? and what did you do to fix it?
  4. Apr 10, 2019 at 3:29 PM
    #84
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    Generally an indication that your trigger and BCG aren't jiving. You're getting hammer follow (trigger resets but then releases as the bolt travels forward, following it forward and striking the firing pin).
    Some triggers are known for it, some trigger just don't like some BCG's. It's a lot more common with 9mm BCG's due to their lack of milspec, different shapes, additional weights, etc. I had the same problem with a Triggertech in my Angstadt 9mm AR. Try a different trigger, if you can. There's lots of triggers developed specifically for the 9mm AR platform.
  5. Apr 10, 2019 at 3:38 PM
    #85
    JustJon
    MI
    18 DCSB OR
    Thanks for the reply,
    I did order an aim surplus flat blade trigger today, and have a pof from another rifle I could try.
    any thoughts on the buffer spring? Some people say standard carbine, some swear by the 308 springs?
  6. Apr 10, 2019 at 3:43 PM
    #86
    Max713
    Max
    Eugene, OR
    2017 MGM TRD OR
    I have not experimented with buffer springs. Buffer weight is much more important. Not saying springs won't make a difference, but 99% of your dampening and cycle rate will come from your buffer weight (when comparing it to the buffer spring, BCG weight is another large factor due to the blow-back operation). I don't think your buffer setup looks bad, and I don't think it has any relevance to your trigger issue. But, experimenting with a heavier buffer could get you a softer shooting rifle.
  7. Apr 10, 2019 at 6:15 PM
    #87
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    I think you have 2 options on your buffer spring setup.
    1. Buy a proven set-up that is made to go together. Several options. Mine: http://heavybuffers.com/uciw9.html
    2. Buy an adjustable buffer and play with it https://www.quartercircle10.com/products/adjustable-pistol-buffer.html & https://www.quartercircle10.com/products/parts-accessories/buffer-spring-xp.html
    I am running a 8.5oz buffer with a specifically matched spring and I have NEVER had a jam or double fire
    I have run a plain CMMG trigger from their parts kit and a POF drop in...zero issues with both.
    Good Luck
  8. Apr 11, 2019 at 5:34 AM
    #88
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I use a 308 spring and buffer on mine. I have a Spinta precision BCR and barrel and that's what they recommended. My AR9 has eaten any ammo I can feed her. I just recently installed a Aimsurplus single stage drop in trigger and still have flawless operation.
    Have you tried a different trigger just to see if there is any difference? Seems like you already have plenty of weight and spring tension.
  9. Apr 11, 2019 at 6:18 AM
    #89
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    My Colt AR9 ....
  10. Apr 13, 2019 at 1:22 PM
    #90
    JustJon
    MI
    18 DCSB OR
    Gonna try a few things as soon as I can get to the range, putting in that aim trigger and will bring both buffer springs.
    I did weigh my bcg and buffer the other day, came to 22oz which I read is right on.
  11. Apr 15, 2019 at 12:58 PM
    #91
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Put a Hogue grip on.
    snowboard704 likes this.
  12. May 24, 2019 at 5:33 AM
    #92
    bringenufgun
    bringenufgun Well-Known Member
    Bill
    OFallon Mo.
    14 Tacoma regular cab 4X4
    none
    Colt DOE clone. protecting nuclear power plants against terrorist attacks in the 80's. also used as transport protection of enriched fuels. folding front sight with flat base to stick through gun ports.IMG_3313.jpg
    same lower with another colt upper and 10" BCM barrel.
  13. Sep 6, 2019 at 3:45 AM
    #93
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    If you're looking for the easiest way to convert your AR.
  14. Nov 1, 2019 at 8:15 PM
    #94
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
  15. Nov 1, 2019 at 8:49 PM
    #95
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Specs?
  16. Nov 2, 2019 at 3:59 AM
    #96
    MidCitiesMildMan
    PSA lower
    ALG QMS trigger
    Spikes mag-block
    PRI Gasbuster charging handle
    CMMG remped bolt
    TROS 5" barrel
    AP Custom CF handguard
    Spikes ST-9x steel buffer
    Magpul grip
    Guntec Minimalist stock
    Liberty Mystix X suppressor
    Primary Arms red dot
  17. Mar 8, 2020 at 3:12 PM
    #97
    RyanFMD
    RyanFMD Well-Known Member
    2018 Quicksand TRD Off-Road
    I'm no ballistics expert but I've heard a lot of people say you get less risk of over-penetration, less noise, and less flash in an HD situation. Maybe others can chime in
  18. Aug 11, 2020 at 9:21 AM
    #98
    Trd420
    Trd420 2nd gen 03
    Tony
    Compton california
    Tacoma trd off road
    Icon stage 4 method wheels
