A 16" Pro comp steel wheel that fits
Discussion in 'Wheels & Tires' started by TYetti, Jan 8, 2016.
  1. Sep 25, 2016 at 1:36 PM
    BCWcrüe
    BCWcrüe Member
    I'm about to pull the trigger and order one to test fit! Look so nice.
    Are they Hub Centric?
  2. Sep 25, 2016 at 1:50 PM
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    When I ordered then I contacted Procomp direct and was told they are tacoma specific. I've had them on for almost a year and they've been great
  3. Nov 20, 2016 at 12:08 PM
    BCWcrüe
    BCWcrüe Member
    Ordered one finally, went to test fit and unfortunately it didn't even make it flat to the hub before making contact with the caliper.
    Oh well. :/
  4. Nov 26, 2016 at 7:44 AM
    TYetti
    Mat
    What bs did you get
  5. Nov 26, 2016 at 9:54 AM
    BCWcrüe
    BCWcrüe Member
    4.25 Back spacing
  6. Nov 27, 2016 at 8:39 PM
    TYetti
    Mat
    I've got the exact wheels 5 of them they fit and don't touch the caliper not sure what to tell you the part numbers I posted are the ones that were on the boxes. I mean it effing close but I can fit a sheet of paper in there so they don't touch
  7. Nov 27, 2016 at 8:41 PM
    BCWcrüe
    BCWcrüe Member
    Yeah I got the exact same as you, part number and everything haha. I did however have new calipers and pads put in and they looked bigger the the ones I had. Maybe they are TRD ones. The wheels almost fit.
  8. Nov 27, 2016 at 8:42 PM
    TYetti
    Mat
    If they're aftermarket it could have something to do with it.
  9. Nov 27, 2016 at 8:44 PM
    BCWcrüe
    BCWcrüe Member
    They came from Toyota, seriously think they might have put TRD calipers on. :notsure:
  10. Nov 27, 2016 at 8:46 PM
    TYetti
    Mat
    Who knows.. could always go to a 17" I suppose they'll for sure fit... sorry it didn't work out for ya
  11. Nov 29, 2016 at 11:36 AM
    rl206
    rl206 Well-Known Member
    P-NW
    2012 Tacoma DCLB
    I tried the D windows and they didn't fit but they were the Cragar's, pretty close, but rubbed the caliper. I actually came accross a part out and am gonna pick up the calipers and see how much I can shave on them, I find it ridiculous the small choice we have to put on these rigs w/ out use of spacers...
  12. Nov 29, 2016 at 12:53 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    Hello all. I don't mean to hijack this thread.
    I have a 99 prerunner. Will the procomp series 51 (d window) fit? If not, what about the series 97? I plan on getting 16x8 steel wheel and put 285/76r16.
    Also, I plan to do a 3inch front 2inch rear lift. Will 3 inches in the front be enough to clear 285s?
    Will doing 3inch front 2inch rear combo be the best height to have a leveled stance front and back? I just don't want the front being noticeably higher then the rear. Thanks!!
  13. Nov 30, 2016 at 6:44 AM
    rl206
    P-NW
    2012 Tacoma DCLB
    My buddy has same gen and thats his setup, 3" and 285's. Not sure on backspacing but his wheels are procomp 1069's I think, I think you should be fine as far as clearing the caliper.
  14. Nov 30, 2016 at 8:23 PM
    TYetti
    Mat
    The d holes do not fit in 16", the 97 series I posted fit they are super tight but they worked for me and continue to work. I've seen them on othere trucks as well.
    You'd have to be more specific about the lift components. you'll probably still rub on the cab mount with 285s cmc is gonna be the way to go there
  15. Aug 20, 2018 at 8:46 PM
    #35
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    Those are steel? What size/offset/price?
  16. Aug 23, 2018 at 6:57 AM
    #36
    TYetti
    Mat
    Just need to update this. Procomp has changed the design of the 97 rock crawler steelies they no longer fit in 16". I also destroyed all 4 of mine. Seriously the steel they used is shit. I went to methods
    EDDO and twhalm like this.
  17. Sep 3, 2018 at 11:55 AM
    #37
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    Thanks for the update
    TYetti[QUOTED][OP] likes this.
  18. Nov 12, 2018 at 8:18 PM
    #38
    WSMFP
    WSMFP Well-Known Member
    Dylan
    2006 Tacoma 4x4 v6 6-speed
    Correct if wrong but these look like the 69 series 16x8 4 in backspacing and -12mm of offset alloy wheels. Just ordered some from 4wheel parts and they showed me several service logs saying that they clear calipers and fit Tacoma’s. If they don’t I can get a refund but I’ve heard mixed things on whether they do or don’t.
  19. Nov 12, 2018 at 8:23 PM
    #39
    TYetti
    Mat
    I am unfamiliar with the 69 series. However I will note that my pro comps bent after a couple trips. After this year's Rubicon trip they were so badly bent I thought I had bent steering components. One also cracked, I replaced them with method race wheels
    WSMFP[QUOTED] likes this.
  20. Nov 12, 2018 at 8:25 PM
    #40
    WSMFP
    Dylan
    Good info to know for sure! Bummer about them cracking! I considered the methods, I try to buy once and cry once but college doesn’t help
