A 20 AMP fuse for (2) 20 watt LED lamps
Discussion in 'Lighting' started by Itchyfeet, Oct 21, 2018.
  1. Oct 21, 2018 at 4:19 PM
    Itchyfeet
    Itchyfeet [OP] Well-Known Member
    I'm still trying to wrap my head around the reason why the harness kit that shipped with my lights has a 20 amp fuse for (2) 20 watt LED lamps. I'm thinking about stepping down to a 5 AMP or 10 AMP fuse. Is there some other reason why the fuse rating is so high?
  2. Oct 21, 2018 at 6:17 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    They probably ship that fuse with ALL of their lighting (pods all the way to 50” bars)
    Ultimately, a 20amp will be fine. It’s just there to keep the wire from catching fire if it shorts out somewhere. It’s not actually protecting the lights. Unless the wiring is super thing gauge (like, 18awg or thinner) then 20 will be ok.
    But, if you have a 5amp laying around, then why not. I wouldn’t buy one just for this though
    Sandman614 likes this.
  3. Oct 21, 2018 at 8:47 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  4. Oct 27, 2018 at 6:12 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    The fuse should be rated lower than the current the thinnest wire on the connection will support. Fuse should blow before wiring gets overloaded during a fault condition. In my opinion you’re better off lowering the value of the fuse instead of leaving it at 20A since I suspect the wiring at the LED lights won’t support 20A.
