A 2nd Gen Resto(ish)/Build(ish)/BS(ish) thread..Taken over by another Tundra, and a Tacoma is back
Discussion in '2nd Gen. Builds (2005-2015)' started by DiamondW, Apr 10, 2019.
  1. Apr 23, 2019 at 2:21 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Your trucks looking mighty fine!!!
    Now a I want a burger from there.
    DiamondW[OP] and BassAckwards like this.
  2. Apr 23, 2019 at 2:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Glad i could be of assistance! :p :spending:
    DiamondW[QUOTED][OP] likes this.
  3. Apr 23, 2019 at 2:22 PM
    DiamondW
    DiamondW [OP] Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    I thought I was pretty good but help never hurts!
  4. Apr 23, 2019 at 2:23 PM
    BassAckwards
    Glad i found someone else in the SA area with a 4.0 that is interested in performance/tuning. The HP thing is seriously a game changer. Gonna tinker with the throttle mapping on mine this weekend and see if it will play nice with my UCON
  5. Apr 23, 2019 at 2:27 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    A money maker to.
    Does it make any real performance gains on a NA motor. I know the speedometer correcting an throttle response is a huge advantage as well.
  6. Apr 23, 2019 at 2:28 PM
    DiamondW
    Kent
    Gonzales Co. TX
    I’m gonna find out from the ground up but it seems like it’s a yes.
    BassAckwards likes this.
  7. Apr 23, 2019 at 2:30 PM
    DiamondW
    Kent
    Gonzales Co. TX
    My plan is to start with just a tune, then start bolting on parts, starting with cam gears and try to dyno here and there to see if we cam put hard numbers on it.
  8. Apr 23, 2019 at 2:31 PM
    BassAckwards
    Yes, ive read it can help with gas mileage as well with a proper tune. The options are literally endless with this. Basically a company finally cracked the toyota ECUs. Companies like URD have stuff like the UCON which is a piggyback ECU that just tricks the OEM computer into thinking it's running the truck.
    This is basically rewriting your ECU with whatever parameters you want. Speed limiter, secondary air injection, and tons of Trouble codes/check engine lights can also be disabled
  9. Apr 23, 2019 at 2:31 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I’m anxious for your results. I do know once I regear an do the smog pump delete I’ll need the ecu corrected. I felt Toyota did a pretty good job tune wise other than the throttle response.
  10. Apr 23, 2019 at 2:32 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    That swaybar link looks like its done for.
  11. Apr 23, 2019 at 2:32 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    I’m familiar with tuning I’ve dabbled in it with the Nissan I had. I’ve also bricked an ecu before not a fun feeling.
  12. Apr 23, 2019 at 2:32 PM
    BassAckwards
    You gonna be the one to install cam gears and then dyno to see the gains on a stock N/A motor?
    I know some folks in the HP thread were talking about the gains from cam gears alone on a stock motor
  13. Apr 23, 2019 at 2:33 PM
    BassAckwards
    I thought i bricked mine last weekend.. i was pissed. My brand new laptop decided to shut down during the middle of a flash.. Needless to say i plugged that bish in after that happened. Started it back up and reflashed it again from the beginning. It is a miracle that it still works imo. Thought i was screwed
  14. Apr 23, 2019 at 2:34 PM
    DiamondW
    Kent
    Gonzales Co. TX
    It really is now since it’s all leaning against my shop wall lol. I’ve got some ready to go if I decide to reinstall.
  15. Apr 23, 2019 at 2:35 PM
    #35
    BassAckwards
    Its pretty cool to start the truck up without that SAI junk. My AFRs are so much more stable now. They used to jump around all over the place while that thing was blowing. Now on start up, they both pop over to 14.7 and sit there. I am happy i no longer have to worry about that stuff failing me and leaving me stranded hundreds of miles from home
  16. Apr 23, 2019 at 2:36 PM
    #36
    DiamondW
    Kent
    Gonzales Co. TX
    I’m hoping too if I don’t get beat to it with my work schedule. Closest dyno is Kyle where I took some diesels.
  17. Apr 23, 2019 at 2:37 PM
    #37
    DiamondW
    Kent
    Gonzales Co. TX
    That would suck.
  18. Apr 23, 2019 at 2:37 PM
    #38
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Ugh you lucked out big time.
    The vendor I bought the tuner from failed to mention to disable any antivirus program before connecting to ecu an I was downloading the stock tune an it. The laptop screen went red an the gauges on the truck twitched an all the dummy lights came on. Went to start an wouldn’t even crank over. Had to take the ecu to the a tuner in ATX they were able to salvage it an gave me some pointers.
    BassAckwards[QUOTED] likes this.
  19. Apr 23, 2019 at 2:37 PM
    #39
    BassAckwards
    How does the dyno work? Im guessing someone else drives the truck on it?
    I want to get mine dyno'd but i want to be the one that drives it since its a manual.. Im pretty in-tune with the noises my truck makes, so if something started to go wrong, i know i'd be able to spot it before someone else who was driving.. May not ever get to dyno it for this reason
    MattCowsmasher likes this.
  20. Apr 23, 2019 at 2:38 PM
    #40
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    This is what I’m looking forward to the most is getting rid of that an possibly adding another battery for the helluva it. Don’t really have any real use for one.
    Beretta4x4 and DiamondW[OP] like this.
