A bad battery that holds a charge?
Discussion in 'Technical Chat' started by adaptedtheory, Jun 14, 2014.
  1. Jun 14, 2014 at 7:58 PM
    adaptedtheory
    adaptedtheory [OP] Well-Known Member
    04 Tacoma S-Runner
    Window Tint, 8" Sundown SA-8, Kicker ZX500.1
    Can a 'bad' battery hold a charge?
    My 2004 Tacoma recently started having trouble when I went out to Texas. It's really struggling to turn over so while it's started every time I have tried recently, I can really hear it working to turn over and it sounds like it's barely making it. I was dealing with acid buildup last year, so I noticed a little acid buildup again when I looked at my battery. It didn't look like nearly enough to give my truck trouble, but I cleaned the terminals and sure enough, it still struggles to turn over. That makes me think either alternator or battery.
    I go to Autozone & ask the fella to test it. He showed me the reading, and it said "Bad Battery - 100%". Kinda dumb looking back on it, but I completely spaced on the voltage reading. I changed the distilled water in it within the last year too, so while I didn't check the water levels, I guess I assumed that wouldn't be the root of the issue. Should I get a new battery or could there be more to this that I'm just not considering because a bad battery that holds a charge? How does that work... I'm no battery specialist I know the basics & that's about it but I'm just trying to understand if that's really the root of the issue. Autozone told me this could be caused by temperature variations but who knows if he actually knew what he was talking about.
    Thanks in advance
  2. Jun 14, 2014 at 8:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    A "bad" battery can still show fully charged (100%) at 12.6 volts. What makes it "bad" is the cranking amps. If the battery is only capable of say 250 cranking amps, but it is supposed to put out 800, then it will be "bad" and slowly crank the engine, while still showing 12 volts.
  3. Jun 14, 2014 at 8:13 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    X2
    If it's original, replace it. You got your moneys worth.
  4. Jun 15, 2014 at 2:58 PM
    adaptedtheory
    04 Tacoma S-Runner
    Thanks for the replies, folks. A couple more details: Today it's cranking but won't start. Pulled the battery, cleaning it up & suppose I will be getting it replaced tomorrow morning. It was manufactured in 09. Bought my taco about 2-3 years ago. Since have added an amp with sub and headunit so it's drawing more power than it used to. Suppose it's still had a pretty good life, at 5 years, but I'm concerned it still might not be the battery for some reason, I just don't have enough knowledge as a whole.
  5. Jun 17, 2014 at 2:20 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    You battery is partially sulfated. Depending on the temperature and condition of the engine, 250 amps might not be enough to start your engine. As it gets colder, you will need more amps to crank your engine and the battery's performance is reduced. For more information on sulfation, see Section 16 in the Car and Deep Cycle Battery FAQ on www.batteryfaq.org.
