a better crimper for non-insulated terminals?
Discussion in 'Lighting' started by super_white, Mar 29, 2020.
  1. Mar 29, 2020 at 4:15 AM
    super_white
    super_white [OP] Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I have an OLS relay/fuse box and I started to install the wires but the crimper I have isn't strong enough. It just folds the tabs over instead of a proper crimp. The metal used for the terminals of the OLS is thicker and you can't get a good crimp.
    This is the crimper I have:
    https://www.amazon.com/Delphi-Packa...coding=UTF8&psc=1&refRID=4MSKKASY55KS8V8F7GTA
    I've seen this on Amazon and I wonder if it would be better:
    https://www.amazon.com/Klein-Tools-...coding=UTF8&psc=1&refRID=MAG4X15PDCM88ESFY8SA
  2. Mar 29, 2020 at 4:31 AM
    NukedTaco
    NukedTaco Well-Known Member
    Wyatt
    Saratoga Springs, NY
    What kind of connectors are you using, un-insulated open barrel?
  3. Mar 29, 2020 at 4:51 AM
    BrownBear80
    BrownBear80 Active Member
    Jay
    Tacoma
    None
    Klein is really good. I’ve used a lot of there tools while doing electrical and it’s precise finish.
    Fire Chicken likes this.
  4. Mar 29, 2020 at 6:02 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I bought this crimping tool just about two weeks ago. The crimper I already had was not going to work for the tiny terminals I needed to crimp.
    So far this one has worked well. Seems to be pretty well made, and certainly comes with a lot of useful extras.
    https://www.amazon.com/dp/B07R2MFCQ...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
  5. Mar 29, 2020 at 6:14 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    This. Using the right crimper for the terminal makes a huge difference.
    TXpro4X4, Lunchmeat79 and paranoid56 like this.
  6. Mar 29, 2020 at 6:19 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  7. Mar 29, 2020 at 6:28 AM
    0xDEADBEEF
  8. Mar 29, 2020 at 6:47 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's very similar to the crimper I have now. I don't think it's the style of crimper but the thickness of the material the terminal is made of.
    DES2009 likes this.
  9. Mar 29, 2020 at 6:56 AM
    0xDEADBEEF
    That could be. They tend to be really sensitive to small differences. Something that ratchets might help for sure.
  10. Mar 29, 2020 at 11:24 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You need one with off sets on the dies. Then it crimps the terminal over wire and terminal over insulated wire. The ratchet style is the best and doesn't over/under crimp. Plus removable dies make it easy to change over to other crimp styles.
    TXpro4X4 and super_white[OP] like this.
  11. Mar 29, 2020 at 3:13 PM
    NukedTaco
    Wyatt
    The middle die for the klein tool you linked should work for those connectors. The crimper you have is for metri-pack and weather-pack terminals which use cable seals.
  12. Apr 3, 2020 at 5:03 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    My Klein VDV200-010 crimp tool arrived today. I had to change the "tension knob" to the lightest setting because where it was I couldn't get the tool open. Yes, I know about the small lever.
    I crimped one terminal for a fuse and the crimp came out good but it's crimping the terminal too much. I'd have to crimp and count the clicks so I don't over do it.
    I'd like to practice but the fuse block did not come with extra terminals :(
    Like I said before, it's like the metal the terminal is made from is too thick.
    Maybe I could try crimping a terminal in the next slot. 18ga. in the 16-14 slot?
  13. Apr 3, 2020 at 5:05 PM
    0xDEADBEEF
    Could the terminals be intended for soldering?
  14. Apr 3, 2020 at 5:06 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Yes, but after you crimp them. They won't fit in the housing otherwise.
    0xDEADBEEF[QUOTED] likes this.
  15. Jul 11, 2020 at 4:54 PM
    Aau80
    Aau80 Well-Known Member
    Alan
    Alexandria Va
    2020 cement taco off-road
    Meso ultimate turn signals, Meso pod lights, bestop soft topper Nothing major... yet...
    Channellock 909 9.5-Inch Wire Crimping Tool | Electrician's Terminal Crimp Pliers with Cutter are Designed for Insulated and Non-Insulated Connections | Forged from High Carbon Steel | Laser Heat-Treated Edges Last Longer | Made in the USA https://www.amazon.com/dp/B00004SBDI/ref=cm_sw_r_cp_api_i_VbLcFbPF0BMP3
    When i use to work at a shop installing TVs and alarms in cars i used these, crimps really well and very durable... sometimes i used them to crimp 4ga wire terminals for grounding amp wires
    Steves104x4 and 0xDEADBEEF like this.
