A better Edge Trim - from Trail Toys
Discussion in 'Trail Toys' started by SMKYTXN, May 30, 2015.
  1. Jun 22, 2015 at 10:18 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    subd. definitly doing this when I trim and put my fender flares back on
  2. Jun 22, 2015 at 11:02 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Glad it worked out for you Jason, and thanks for the kind words. Definitely looks a lot better than the cheap vatozone trim hanging off the fenders. :D
    Chop Chop! :D
  3. Jun 30, 2015 at 4:47 PM
    2ndGenJonny
    2ndGenJonny Well-Known Member Vendor
    Jon
    Gilbert, AZ
    Subd for upcoming :sawzall:
    285x75r17 on the way
    SMKYTXN[OP] and Sje1124 like this.
  4. Jun 30, 2015 at 6:28 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  5. Jul 3, 2015 at 3:11 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Take 10% off your order from now through July 6th. PM me to place an order.
  6. Jul 6, 2015 at 11:40 AM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Not ready for 35" tires, but I just ordered some for my new high clearance bumper. Looks like a great product.
    Edit: Ordered on your web site then saw your post above to PM you. Oh well. Haha.
  7. Jul 6, 2015 at 12:33 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Thanks for the order Jesse. You didn't miss out on much though, I'll throw an extra decal in though. :D
  8. Jul 7, 2015 at 4:26 AM
    crazy joker
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Haha, thanks, but I wasn't worried about it with such a tiny order. Just thought it was funny that I didn't read 1 post up.
  9. Jul 7, 2015 at 6:31 AM
    boatbuilder
    boatbuilder Well-Known Member
    Jim
    Tonasket, WA
    12 regular cab 4 cyl 4wd
    A lot!
    You guys have never heard of TrimLok? It's the same stuff. Been around for 30 years or more. I've used it for 20+
  10. Jul 7, 2015 at 6:44 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yes, this is a TrimLok product, what's your point?
    I found the right trim that works for our sheet metal and bought a bulk roll from the manufacturer. You'll find my cost per foot lower than anyone else selling this particular trim as well.
    Thanks for the bump.
    PinnaclePete likes this.
  11. Jul 7, 2015 at 7:26 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I'll need some of this when I go dirty fives.
  12. Jul 8, 2015 at 2:10 PM
    crazy joker
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Showed up at my house super fast! Thanks!
    SMKYTXN[OP] likes this.
  13. Jul 8, 2015 at 5:42 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    @tacopaulo you should get this. Looks good on red!
    @EddyRRT
    tacopaulo likes this.
  14. Jul 8, 2015 at 5:57 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    How many feet would I need for 4 fenders and a high clearance bumper? My auto parts crap liner is hanging on by a thread lol
  15. Jul 8, 2015 at 6:20 PM
    #35
    SMKYTXN
    Nathan
    Houston
    DCFB
    Twenty feet seems to be the right amount for four fenders and a high clearance.
  16. Jul 8, 2015 at 6:23 PM
    #36
    PSU Taco85
    optional
    Thanks, I'll be placing an order this week.
  17. Jul 8, 2015 at 6:25 PM
    #37
    SMKYTXN
    Nathan
    Houston
    DCFB
    :thumbsup:
  18. Jul 8, 2015 at 11:23 PM
    #38
    boatbuilder
    Jim
    Tonasket, WA
    A lot!
    Point is you make it sound like it's some new wonder product, which it's not. After using TrimLok for 20+ years I would highly suggest you glue it on being upside down because the dirt accumulation will make it slide right off in time. Slicone will both adhere and seal it from dirt. Just a suggestion.
  19. Jul 12, 2015 at 8:47 AM
    #39
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I understand that you have some previous experience with this stuff so do I but the Op didn't say anything misleading and you're being a bit harsh for no apparent reason ? He found a product that is definitively better than the door edge guard from Pep Boys most people are using for this and he is just sharing it as a better solution. I guarantee you that 99% of the people on this forum did not know this product existed. Silicone is a bad idea on any metal application including sealed and painted metal. Silicon traps and releases moisture for a long time, long after it appears cured. That trapped moisture can and will cause rust even through paint. In my experience working with custom automotive applications urethane is stronger and does not have the moisture issue that silicone does.
    Now, all that being said I agree it does loosen up over time those of us that have worked with it have unboubdetly spent time re pinching it tighter with pliers. Boatbuilder's suggestion of adding a sealant is a very good idea because it will keep water and grime out over time. Water will get in and you don't want that water sitting in there with your cut metal edge. After you install the molding use masking tape to tape off the body as perfectly against the edge of the molding as you can. Then remove the molding and scuff the paint with a scotch pad and use a good degreaser or wax remover to make sure it is squeaky clean and reapply the molding. Apply a very very thin bead of urethane then wet your finger and smooth it out and pull the masking tape. If you use black urethane it will be nearly invisible and seal that edge and help keep the pitch molding in place forever. I repeat apply very very little urethane because you are just creating a micro seam seal you are not caulking your windows.
    Biscuits, Ugly Betty and SMKYTXN[OP] like this.
  20. Jul 17, 2015 at 9:09 AM
    #40
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Have we determined if this works on the 2nd gen fender flares?
