a bike under tonneau cover ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by strictlys, Mar 7, 2016.
  1. Mar 7, 2016 at 3:58 AM
    strictlys
    strictlys [OP] Well-Known Member
    2016 Super White Tacoma DC TRD OR SB
    Sorry for a stupid question, but I don't have a bike to put in back of my truck to try out currently. I am planning to to purchase a 27.5 size med mountain bike and wanted to make sure i can fit it back of my short bed locked with the tonneau on. Most likely what is going to happen is after work I will ride, but i need it to be under the tonneau since my vehicle is my business vehicle its parked everywhere on the streets unattended. For the weekend I plan to buy a tailgate pad.
  2. Mar 7, 2016 at 4:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    With a SB I'd want to try it, but with my LB it's not a problem, and mine is a 2G
    IIRC isn't your 3G bed a bit deeper than the 2Gs were? That will help you.
    Depending on the shape of your bars, you 'might' have to loosen them for a bit of turn to get it down lower.
    Of course you know to load it derailer up. It might also be helpful to pop off the downside pedal.
  3. Mar 7, 2016 at 4:49 AM
    gdb85
    gdb85 Well-Known Member
    Pgh, Pa
    2016 SR5 DCLB 4x4
    I have a soft cover trifold on mine (which gives an inch or so more space than hard) and the front wheel needs to be removed to get the bike to lay flat and not be noticeable under the cover. I'm sure you'll need to do the same with a hard or soft cover.
  4. Mar 7, 2016 at 12:22 PM
    stolenword
    stolenword Active Member
    I am able to fit my 29er in my short bed with the cover down (factory). I just have to lay it down diagonally. It is a tight squeeze but doable. A 27 should be even easier.
    TempleRidesNepal likes this.
  5. Mar 7, 2016 at 12:36 PM
    gdb85
    Pgh, Pa
    2016 SR5 DCLB 4x4
    Hmm...interesting. I may need to whack my handle bars down a bit, lol.
  6. Mar 7, 2016 at 5:00 PM
    strictlys
    do you have to remove your wheel? full suspension or hard tail?
  7. Mar 7, 2016 at 7:20 PM
    Jaybez
    Jaybez Well-Known Member
    Fort Mill, SC
    2016 Tacoma TRD Sport 4X4
    If you take the wheel off the front, you should be able to turn the handle bars and slide it under.
    The problem I would have is driving around all day like that. Seems like a great way to break or bend your components.
    Just buy a rack with a lock. Or buy one and get a separate lock.
  8. Mar 8, 2016 at 3:39 AM
    stolenword
    I leave the wheel on. I just have to turn the handlebar slightly. For reference I ride a 2013 Trek X-caliber hardtail
  9. Mar 8, 2016 at 4:05 AM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    This depends on wheel size or bar width. Take the front wheel off or losses the stem to make it fit. Don't cut your bars! Wider bars ( as long as they fit you) are great for riding!
  10. Mar 8, 2016 at 6:30 PM
    Mike_Lowrey562
    Mike_Lowrey562 Well-Known Member
    Long Beach, CA
    2016 TRD OR MGM
    I take my front wheels off and it fits just fine.
