A/C air compressor
Discussion in 'Off-Roading & Trails' started by Dom, Aug 6, 2011.
  1. Aug 6, 2011 at 8:52 PM
    Dom
    Dom [OP] happy new year!
    Dom
    Vancouver Island
    98 tacoma 4x4
    2" lift, leaf pack, rear tube bumper, front bullbar
    the way i see it you dont need the luxury of air conditioning in a beat up 4x4..
    has anyone out there moded they're a/c pump to pump air?
    the pump is cooled by the freeon in the a/c system so if there was a way to run engine oil through it to cool it and still pump air. can it be done??
    i've seen old oil cooled a/c pumps adapted on to 22rs but not on the 3rz
  2. Aug 7, 2011 at 8:32 AM
    Bawlzdeep
    Bawlzdeep I'm dropping the hammer
    Jon
    Penn Valley CA
    S/C'd 97 4Runner 5spd
    lift, tires, winch, 5spd swap, dual lockers..
    I'm sure it could be done with an oil separator/catch can set up of some sort. I love my A/C! Just put in a new compressor a month ago.
  3. Aug 7, 2011 at 8:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its been done on older compressors, but the new ones require a lube (carried by the R134), to avoid siezing up. Not sure how long it would last as an air compressor.
  4. Aug 8, 2012 at 8:08 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I've seen them on cheeps. Mist oiled on intake and seperator on exhaust. I would love to have one. I have also read a write up using a sanden with a grease fitting and the guy shoots it with grease from time-to-time. I'd prefer the oiled and separator set up. Better yet have a pickup in the separator that takes oil from the separator. You'd just would want to make sure you drain the water (from compression the air) regularly and tap into the separator at a level that would allow some water to collect so that you're not sucking water everytime its in the separator.
  5. Aug 8, 2012 at 8:23 PM
    06TRDZombieHunter
    06TRDZombieHunter Well-Known Member
    Robert
    Hillsboro, OR
    06 TRD Sport DCLB
    K&N Intake System Port and Polish of TB x2 E3 Diamondfire Sparkplugs 2.5" Leveling kit 32" BFG A/Ts Zombie Response decals Custom painted grill, trim under headlights, scoop, intake and manifold. No more mud flaps, Temp gauge inside intake box, BHLM, extra D-rings in front of bed, No more plastic storage box behind rear seats. More to come.
    I'm not sure if I understand the original idea... You want to ditch the A/C and use the compressor to move air? For like on board air, filling tires and such?
    If so, Harbor Freight has a 12volt compressor that is about the size of a RedBull with a handle, and its high capacity. Fills my 33" BFG A/T flat in about 5 mins to 40psi. I think I paid $20.
    But its not nearly as cool as making your own out of parts you dont want anymore..:cool::cool:
