A/C and heater causing mpg to drop to 11mpg from 19mpg...normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by COoffroad, Jul 16, 2013.
  1. Jul 16, 2013 at 10:59 PM
    COoffroad
    COoffroad [OP] Member
    My rig - 2009 Tacoma 4x4, 67,000 miles.
    Hi, after racking my brain for the last 6 months where I have seen my mpg drop from about 19-20 highway to about 11-12 highway and doing everything I could find recommended on this forum including maintaining tire pressure, oil changes (synthetic), changing my spark plugs, changing the air filter (and in-cabin filter too), cleaning the MAF, running 2 cans of Seafoam, a can of Duralube injector cleaner, buying non-ethanol gas, non-winterblend gas, only running premium for a few tanks, etc. I couldn't figure out why I was getting such bad mileage and gave up for the last month.
    I drive a lot. Like, all year round, all seasons. This truck sat virtually unused for 2 years while I had a company truck so all those miles were fairly recent and I monitor my gas mileage constantly, virtually every tank.
    Today I decided to drive without using my air conditioner since I was mostly in the cooler mountains and bam, I was up to 20mpg again. Drove 390 miles today total so got a pretty good gauge.
    First question, is it normal to have the gas mileage drop to 11mpg when using the A/C on a 2nd gen Tacoma? It seems incredibly excessive to me. Seems like it was dropping maybe 4-5mpg max (usually less) for most the time I owned the truck, not 10mpg.
    Second question: I'm still getting like 11-12 (sometimes as high as 14) in the winter when I'm not using A/C at all. Since the in-cabin air filter is new (and I keep it clean), why is the heater causing my gas mileage to go down almost as much as the A/C does?
    Thanks for the great resource! I've been lurking the threads for years, anytime I google a question I usually end up here. Can't find an answer to this one though.
  2. Jul 16, 2013 at 11:09 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Either defrost setting cycles the AC
  3. Jul 16, 2013 at 11:14 PM
    aj hank
    aj hank Well-Known Member
    AJ
    412 PA
    09 Regular cab
    Hi/lo HIDs, window tint, keyless entry
    I have an 09 4x4 regular cab and I have my ac on 95% of the time , even if it's on low with the window (I have cranks and am too lazy to reach across most of the tiem) down. I get a consistent 19-22mpg. Something's not right about your mileage.
  4. Jul 16, 2013 at 11:42 PM
    COoffroad
    Ok thanks, I figured the mpg was dropping way too low to be normal.
    I should also add I had my catalytic converter checked and was ok. And also, I don't seem to be experiencing any large (if any at all) drop in power, no engine sputtering, rough idle, or anything out of the ordinary. Just horrendous gas mileage until today.
    Also, sometimes when I have the a/c or heater on when I start my truck there is a quick grinding sound when I first start driving off, coming from somewhere near the center of the engine compartment slightly off to the drivers side and it drags the truck power way down for about 1/2 a second and then I'm fine for the rest of the day.
    I guess my question now would be, can anyone think of a reason running the heater or a/c would cause such a huge drop? It doesn't make sense to me. I'm at a loss for things to check at this point and hoping someone could provide some direction for a guy who's truck knowledge is entirely composed of from what I learn on the internet.
    Thanks!
  5. Jul 16, 2013 at 11:51 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    something's definitely wrong. i run my ac 24/7 usually and get 18-20 on the highway.
    now whats wrong? I'm not sure..
  6. Jul 17, 2013 at 2:37 AM
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    Brake dragging? My old car did that, couldn't figure out wtf was wrong for the longest time.
  7. Jul 17, 2013 at 4:38 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    The noise you heard could be the A/C compressor grinding, and a problem with the compressor could explain why the mpg drop. Did you notice the noise when you start to drive with the A/C turned off?
  8. Jul 17, 2013 at 5:44 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  9. Jul 17, 2013 at 9:34 AM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    Sounds like time for a new A/C compressor....
  10. Jul 17, 2013 at 9:42 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  11. Jul 17, 2013 at 10:27 AM
    GTOJim
    GTOJim Well-Known Member
    Jim
    SF Bay Area
    2013 PreRunner TRD OffRoad V6
    When using just the heater the AC compressor doesn't or shouldn't cycle on and off so it should not have any impact on fuel mileage. The defroster uses the AC to dehumidify. The heater alone does not use AC.
    In theory using AC on the highway with windows closed will provide better fuel mileage than no AC with windows open.
    At highway speeds are you feeling a drop in power when the AC compressor cycles on?
  12. Jul 18, 2013 at 6:21 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Just checked mine. First time in a couple of months that I have not towed boat. 4000 on ODO and 21.1 mpg. Mainly hwy back and worth to work. 70 mph with AC on 1/2 the time.
  13. Jul 18, 2013 at 7:08 AM
    BamaToy1997
    Bill
    Navarre, FL
    Bingo
    True, technically. However I have learned over the years that when someone says they "turned on the heater" they just assumed that any time the temp knob was in the red, it was the heater. Perhaps the OP can give us more information.
    OP, when you say you use the heater in the winter, what settings do you have it on? Defrost, or dash/floor heat only?
    I would say that if it is truly the AC system reducing your mileage that much, I would have the compressor and pulley inspected to be sure that the compressor is not trying to seize up or drag.
  14. Jul 18, 2013 at 10:35 AM
    oldstick
    oldstick Medicare Member
    GA
    That is very interesting. I did experience a similar problem with a Ford Windstar one time when the thermostat was replaced with a different, lower temp, rated one than the original.
    But in that case the car would skip and run rough when it was extremely cold then a code was thrown indicating the engine coolant temp was dropping too low.
  15. Jul 18, 2013 at 11:00 AM
    stump jumper
    Bill
    Texas
    I turn mine off manually most of the time. The only time I really need the A/C to run with defrost is right after start up on damp mornings when the inside is fogged.
  16. Jul 18, 2013 at 12:39 PM
    BamaToy1997
    Bill
    Navarre, FL
    I agree, you would think there would be. but a compressor that perhaps is causing an additional 10% drag might not make a noise, but would certainly cause a serious lack of performance and reduced fuel economy. Of course we are ALL armchair-diagnosing things here. lmao.
  17. Jul 18, 2013 at 3:47 PM
    OZ-T
    Peter North
    British Columbia
    wut
  18. Jul 18, 2013 at 3:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Perhaps the engine serpentine belt tensioner is on it's way out. Sunoco cheapo fuel, stay off the throttle and Granny shift is all I can come up with for the fuel economy dilemma. Good luck.[​IMG]
  19. Jul 18, 2013 at 4:04 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
  20. Jul 18, 2013 at 4:11 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
