A/C bad smell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ding King, Nov 2, 2010.
  1. Nov 2, 2010 at 1:39 PM
    Ding King
    Ding King [OP] Well-Known Member
    Parts Unknown
    TRD SPORT 4x4
    5100's all around fronts at .85,rear TSB,trans TSB,20% tint,TRD exhaust, TRD CAI,tailgate mod, bed mat, Extang Solid Fold, EGR in-channel, Nitrofil.
    I have a bad smell that comes out of my a/c vents when I turn it on. It last about 10 mins. then seems to go away. Smells like mildew and crap. Any thoughts out there?
  2. Nov 2, 2010 at 1:48 PM
    zx5go
    zx5go Well-Known Member
    Southwest Missouri
    2011 Super White TRD Sport
    From past vehicles I would say you're dealing with mildew growing from moisture build up in the system. One way to avoid this is to run the fan on high for a couple of minutes without the AC on before you shut your vehicle off. I assume this is to allow the moisture some time to get out of the system. My previous car was a MazdaSpeed3 and there was actually a TSB for smells coming from the vent and this was the solution.
  3. Nov 2, 2010 at 1:51 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    Just had this issue with my FJ. Sucks. It caused by condensation in your AC system which forms when you run the AC then turn the car off and don't let it air out. This is especially true if you use the recirculate button. You should turn the AC off a few minutes before arriving at your destination, and maybe even run the fan alone to let it clear out.
    I fixed mine with a whole can of Lysol. Sprayed it into my ac air intake (near
    Front windshield/wipers). I sprayed a can while running the AC, and some more while just running the air. Worked and it's finally clear. Took a good month for it to go away after treatment.
  4. Nov 2, 2010 at 1:55 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Spray Lysol into the intake air vents at the base of the windshield. Problem solved. I love it when us old farts know the answer!
  5. Nov 2, 2010 at 1:55 PM
    Ding King
    Parts Unknown
    TRD SPORT 4x4
    Thanks guys. I thought that could be my issue. I drive in the heat then my truck is parked in a very cool garage. (It is a drive under) I will try to run the fan more with air off.
  6. Nov 2, 2010 at 1:55 PM
    Ding King
    Parts Unknown
    TRD SPORT 4x4
    I will try Lysol too
  7. Nov 2, 2010 at 2:09 PM
    zx5go
    Southwest Missouri
    ...my dad parks in a drive out basement that is cool/moist. He hasn't found a fix and I don't know if just drying out the AC will help. The smell seems to invade both of his vehicles from the cool/moist environment in the basement. Might help to put some something like DampRid in the garage.
  8. Nov 2, 2010 at 2:10 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You may want to change your cabin filter located behind the glove box.
  9. Nov 2, 2010 at 2:13 PM
    Ding King
    Parts Unknown
    TRD SPORT 4x4
    I changed my cabin filter. It looked new. Damp rid may be an idea. Sounds like I have ZX5go issues. My other truck does not seem affected though. BTW Italian, your speaker setup is PIMP
  10. Nov 2, 2010 at 2:31 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Thanks man!
  11. Nov 2, 2010 at 2:44 PM
    zx5go
    Southwest Missouri
    Is it still thread jacking if the OP starts it? :)
    That is one cool speaker setup! Sign me up.
  12. Nov 2, 2010 at 5:14 PM
    Raven65
    Raven65 Well-Known Member
    Camden, SC
    '09 Magnetic Gray Reg Cab 5-Lug
    Curt hitch, D-rings, bed mat
    You'll want to remove the cabin filter BEFORE spraying the Lysol in the intake duct - or the filter will trap most of it. Spray the filter itself when you have it out too, but you need the Lysol to make it through the whole duct system.
    I haven't had this problem in my truck yet, but we have with my wife's '07 Camry (and the Lysol trick worked on it). Just about every time I get in it, she has left the temp dial on full cool - which automatically switches the system into recirculate mode (true on my truck too). If you spin the temp dial to full cool and then back it off one click, it'll switch to fresh air mode. All you have to do is look at the recirc switch as you do this. Light on = recirc mode... light off = outside (fresh) air. I think you can override either of these behaviors by pushing the recirc button manually after setting the temp dial where you want it - but that's what happens automatically.
    Anyway... when I run the A/C in my truck, I always push the A/C button to turn the compressor off and just let the fan run wide open in fresh air mode when I'm a couple of minutes away from my destination, so that any condensation inside the ducts will hopefully dry out by the time I reach my destination and shut everything down. So far, so good.
  13. Nov 5, 2010 at 8:44 AM
    hgfontana
    hgfontana Well-Known Member
    Hernan
    Resda, Ca
    12 Tundra CrewCab 4x4
    I had a 2007 Tacoma for 3 weeks and it have the same problem. At this moment I thougth was a bad air cabin filter and thought to change it but then I bought a brand new 2011 and it have the same problem. I saw in the posting how to solve it (thanks!) but my question is why that smell don't happen ever before in my Odyssey or happen in my wife CRV? Somebody have the same problem in other car?
  14. Nov 5, 2010 at 8:50 AM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Seems to be a common problem for our tacomas.
  15. Nov 5, 2010 at 11:30 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    If it smells like CRAP, then you have a completely different issue...:crapstorm:
