a/c blowing frost out the vent
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wilytoy01, Aug 14, 2025.
  1. Aug 14, 2025 at 12:17 PM
    wilytoy01
    wilytoy01 [OP] Well-Known Member
    2023 blue tacoma Sport
    Has anybody’s a/c vent blowing out frost out there vent anytime mine’s been doing it when it’s really hot outside
  2. Aug 14, 2025 at 12:18 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Your system is likely slightly undercharged.
    jpg366 likes this.
  3. Aug 14, 2025 at 12:54 PM
    Midnight beauty
    Midnight beauty Well-Known Member
    White mountains AZ
    2020 midnight black Tacoma TRD Sport
    Could have a plugged drain hole
    wilytoy01[OP] likes this.
  4. Aug 14, 2025 at 6:44 PM
    wilytoy01
    I will check it thanks for the information
  5. Aug 14, 2025 at 6:46 PM
    wilytoy01
    I will check in that as well thanks for the information
    Taco Egghead likes this.
  6. Aug 14, 2025 at 6:54 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does it eventually stop, then have very reduced airflow?
    That's a symptom of an eval icing over. Usually due to a bad thermistor
  7. Aug 16, 2025 at 6:34 AM
    wilytoy01
    Thanks I will check it as well thanks for the information
  8. Aug 16, 2025 at 6:52 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If the outside humidity is very high and you do not have the AC mode switched to recirculation, you can get frost out the vents.
  9. Aug 16, 2025 at 4:19 PM
    Liquorguy16
    Liquorguy16 Well-Known Member
    Central Oregon Coast
    2016 Taco Off Road Access Cab Quicksand
    Pizza Cutters Dog Hair, Multiple Dents and Scratches
    That's cold bro:rimshot:
    wilytoy01[OP], t0p_d0g and koditten like this.
  10. Aug 16, 2025 at 5:45 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Sitting here wishing mine got that cold lol.
  11. Aug 16, 2025 at 7:43 PM
    t0p_d0g
    t0p_d0g My Tacoma is my happy place
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    My Aunt had a Dodge “R12” of some kind don’t remember the model it was but it blew frost out the vents. They wasn’t anything wrong with it but cold ass air.
    The evaporator wasn’t freezing up cause it would do it on a three hundred mile trip and the CFM would never change.
    wilytoy01[OP] and Phlogiston like this.
  12. Aug 16, 2025 at 9:34 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    Same. My A/C is horrendous when driving around town. It does get much better on the freeway.
    islandhiker likes this.
  13. Aug 16, 2025 at 10:30 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  14. Aug 16, 2025 at 10:31 PM
    OnHartung'sRoad
  15. Aug 17, 2025 at 7:06 AM
    Beerpayzdabillz
    Nor Cal
    2016 DCSB 4x4 sport
  16. Aug 17, 2025 at 8:49 AM
    OnHartung'sRoad
    You can do it pretty easily yourself though- I ended up doing it because I didn’t want them doing all the work behind my dash that Toyota prescribed. So add your own fan, a simple relay off the battery and a switch in the cab and it’s done and it will work a lot better.
  17. Aug 17, 2025 at 9:39 AM
    Palomar Taco
    Palomar Taco Well-Known Member
    Aaron
    So FL
    '23 Taco SR5 2wd Street Truck
  18. Aug 17, 2025 at 9:56 AM
    t0p_d0g
    If you have a 16 - 20.
  19. Aug 18, 2025 at 4:35 PM
    Beerpayzdabillz
    Nor Cal
    2016 DCSB 4x4 sport
    Thank you for the tip. So, is this right, just adding a second fan to the radiator improves my a/c temp?
  20. Aug 18, 2025 at 6:51 PM
    OnHartung'sRoad
    Yes, it’s exactly the same fix Toyota does for that TSB except they go into a lot more trouble to make the fan run automatically whenever your AC compressor is on, but a lot of of us here bypassed all that and just did it ourselves with a relay and a switch.
    This is the set I got, I was going to install both but I got lazy and only did the passenger side due to the oil cooler getting in the way. But it works a lot better now with even just one, and I have a spare to use as a replacement or for other things.
    https://a.co/d/i9IWZUG
