A/C blows cold on drivers side/hot on passenger
Discussion in 'Technical Chat' started by Sky King, Jul 10, 2015.
  1. May 11, 2020 at 2:40 PM
    #41
    AZDirtyTaco
    AZDirtyTaco Active Member
    Ricky
    AZ
    TRD Offroad
    Stage 4 ICON 2.5 w/ remote resi front/rear - ICON AAL - Camburg UCA - 275R17 Nitto Trail Grappler's on ATX Artillary's
    Condensor has minimal signs of wear due to road debris and whatnot. 99% of the fins are clean and in great shape. My truck only has 77k on it so it's a huge bummer to think that I've got some major overhaul needed for anything mechanical that isn't directly related to me beating on it.
  2. May 11, 2020 at 2:41 PM
    #42
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I still have no idea how my evap core developed a leak!
  3. May 12, 2020 at 5:31 PM
    #43
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    As a tech who has had experience with this concern I would check the following. Are both heater hoses going in and out of the heater core hot?. If so you may have a partially plugged heater core. Most cores lay in the heater box so half is on the driver's side and the other half is on the passenger side. The antifreeze may only be circulating through half the core due to being plugged. Try flushing the core. Don't waste your money on flushing solutions. A good dish detergent works great. Hope this helps.
    AZDirtyTaco likes this.
  4. May 16, 2020 at 10:00 AM
    #44
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    Hey guys, I did a recharge on mine and it has been working fine as of now. I am waiting for a warm day to turn the A/C on. I think my freon was low. I inspected all the hoses and my cooling system and I did not see anything that is raising a res flag
    Sugar Silva likes this.
  5. May 17, 2020 at 10:58 PM
    #45
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    When driver's side blows warm and passenger side blows cold or vice versa it is usually due to low refrigerant. There's something about the refrigerant changing states too soon as it moves across when its low.
    The AC compressors have a seal at the front shaft that leaks over time because of the design, so the systems will need to be topped off after a few years even if all the o-rings and hoses are not leaking.
  6. May 21, 2020 at 3:05 PM
    #46
    AZDirtyTaco
    Ricky
    AZ
    TRD Offroad
    I lucked out assuming I wasn't fed a line. Turned out that the new shrader valve was faulty. It's been blowing cold since they fixed it about 2 weeks ago. I didn't want to post my experience until I was more confident that it was going to maintain. Whew...
  7. Aug 12, 2020 at 8:54 PM
    #47
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    I’m having this problem. Left vent is the coldest and it’s progressively warmer to the right. Fingers crossed it’s just low
    PennSilverTaco likes this.
  8. Aug 12, 2020 at 8:54 PM
    #48
    PennSilverTaco
    Charlie
    Have them put dye in the system...
    Sugar Silva[QUOTED] likes this.
  9. Aug 13, 2020 at 11:42 AM
    #49
    Sugar Silva
    Dave
    San Diego, CA
    I have an appointment with my local guy to do just that on the 21st. I'll update here. How's your dash after they put it back together? Did you have any new rattles?
  10. Aug 21, 2020 at 3:08 PM
    #50
    Sugar Silva
    Dave
    San Diego, CA
    Update - My local guy found I was low and needed a charge. He said after that it is blowing cold like it should. He put dye through it and doesn't see an leaks right now but said if it (fingers crossed it doesn't happen) it stops blowing cold again to come back and he will look for pin hole leaks. I'm picking it up in an hour.
    Update: So far so good! Blows colder from all vents than it did when new. Hope it sticks
  11. Jun 11, 2024 at 12:46 PM
    #51
    tacodetw
    tacodetw Active Member
    2005 DCSB OR
    can i simply pour more coolant in my line or need to take this in? thanks!
