A/C blows weak AF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cpeterson12, Jul 10, 2020.
  1. Jul 10, 2020 at 8:51 AM
    cpeterson12
    cpeterson12 [OP] New Member
    So i live in southern Utah and the summers get quite hot. My A/C blows pretty weak on high. Ive taken the cabin filter out to see if i had restriction, No change. Im just curious if theres some simple fix that will improve my output.
  2. Jul 10, 2020 at 8:58 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends just what is wrong .
    Could be blocked or separated duct work . rodents love to raise kids in them.
    Fan Motor just getting tired or extra resistance in the high position circuit slowing the motor
  3. Jul 10, 2020 at 9:03 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Do the dash vents start cold on the driver's side and get warmer on the passenger side? That's a sign of a low charge.
    If it is low, then you have a leak somewhere in the system, a it's a closed system.
    Craftsman makes a UV flashlight and sold at Lowe's. That's how I found mine.
    What about the fan itself; is it working properly? If not, look at the fan speed resistor, blower motor and HVAC wiring connectors. All are known trouble spots.
    Good luck.
    TnShooter and Zac of all trades like this.
  4. Jul 10, 2020 at 1:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jul 10, 2020 at 1:12 PM
    TnShooter
    Deogee
    STOCK
    We need to go ahead and get some questions out of the way.
    1. Does the A/C feel cold at all vents?
    2. Does the air speed from the vents change with each change of the seep dial?
    3. Do all the setting on the A/C work?
    4. When you switch from Floor Vents to Dash Vents, is there a change in Volume of air output?
    5. Are you willing to pull a few connectors, and inspect for problems?
    6. Do you own and know the basic operations of a Volt/Ohm Meter?
    Larzzzz and CurtB like this.
  6. Jul 10, 2020 at 1:42 PM
    DG92071
    DG92071 Well-Known Member
    Mine started doing this crap 3 days ago. I unplugged the blower motor to see if the connector was burnt or corroded, it wasn't, so I plugged it back in and now it's fixed. Lol.
    Larzzzz and TnShooter like this.
  7. Jan 14, 2023 at 9:11 AM
    PhxRising85
    PhxRising85 AMSOIL Dealer
    Logan
    Surprise, AZ
    2008 SR5 2WD LB Tacoma
    Fox 2.0 Suspension, Diode Dynamics Driving Lights, AMSOIL
    Living here in AZ, I find the amount of air output in my Tacoma to be really weak. It pretty much has to be on 4 or high to get any decent amount of air out.
