A/C Compressor and No heat
Discussion in 'Technical Chat' started by dman374, Apr 29, 2018.
  1. Apr 29, 2018 at 3:01 PM
    dman374
    dman374 [OP] Member
    09 Tacoma off road package 4X4 SR5
    Serpentine Belt went... changes all pully's and Belt, (have brand new belt tensioner for sale, missing pulley), ok just noticed that the AC compressor gear is being engaged when I turn the drfrost on... it also intermidtently stops spinning which inturn stops the belts free spinning pulley to stop spinning. Removed the AC 10 Amp fuse so it does not come on when I turn the defrost switch on...why would it do that? Also I took out the AC/Heater control assembly to check continuity on the AC push button to see if faulty, I put it back together and now the blower motor will not turn at all. any help would be appreciated.
  2. Apr 29, 2018 at 3:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm pretty sure that AC is always on for defrost. It's so it blows nice dry air to defrost the windshield. I'd search around and confirm.
  3. Apr 30, 2018 at 1:19 AM
    dman374
    dman374 [OP] Member
    the main problem is that the clutch of the ac comp stops the belt pulley from spinning so I beleieve the ac comp maybe going bad?
  4. Apr 30, 2018 at 1:20 AM
    dman374
    dman374 [OP] Member
    would ac comp come on only when AC button pushed in?
  5. Apr 30, 2018 at 1:28 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    ac comp will come on only when a/c button is pressed or when defrost is used. if the pully is seizing up the compressor could be failing OR the bearing in the pulley could be going bad.
  6. Apr 30, 2018 at 1:34 AM
    dman374
    dman374 [OP] Member
    Since I probably have to change the ACcompressor, which brand and from where have the Tacomaworld members recommend. And is a easy change...Meaning to I have to recharge the system?
  7. Apr 30, 2018 at 4:50 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Yes you need to evac and recharge for changing the compressor, and the better vac you get on the system the cooler the system will blow, denso makes compressors, wouldnt be suprised if its a denso from the factory.
  8. Apr 30, 2018 at 5:55 PM
    dman374
    dman374 [OP] Member
    blower motor resolved I forgot to put spring back under metal plate.... metal plate was not making contact when I turned the blower motor fan speed ... I'm embarressed
