A/C Compressor Belt...cut??
Discussion in '1st Gen. Tacomas (1995-2004)' started by fatban, May 25, 2011.
  1. May 25, 2011 at 10:28 AM
    fatban
    fatban [OP] Member
    Hi I have an 04 tacoma with a v6. My ac compressor does not work and I have got a weird noise going on, that I think is from a locked ac compressor. Im wondering if cutting the belt to the ac compressor will affect anything else? I see it touching one other wheel from the main shaft but im not sure if this is just for tension or what....any answers please??
  2. May 25, 2011 at 10:39 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    Toyota TRD Pro Grille, Skid Plate, ARE Series II Lid,
    That truck has 3 belts,
    One should be for the ac comp.
    One for the alt.
    The third is the power steering
    Is your ac comp frozen? You don't need to cut it, just loosen up the ac comp and remove it.
  3. May 25, 2011 at 4:42 PM
    tommyc
    tommyc Well-Known Member
    tommy
    4X4 SR5, TRD
    Dude 03's right, why do you have to cut everything up like a butcher? Loosen up a few bolts slide it off. The belt is still good? Right
  4. May 25, 2011 at 7:08 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    or you can just cut it off..not like hes going to use the AC
  5. May 26, 2011 at 3:51 AM
    fatban
    fatban [OP] Member
    ok so its def AC only...so im gonna remove but ya to even get a good angle to remove bolts just seems way to hard as opposed to just cutting the darn thing
  6. May 26, 2011 at 3:54 AM
    fatban
    fatban [OP] Member
    yes the belt is still good...but its the belt in the middle of the 3....and say i do get the bolts removed...that would mean i would have to remove all 3 belts to get it out of there correct? sounds like way to much time to me
  7. Jun 23, 2011 at 1:40 PM
    atapia22
    atapia22 Well-Known Member
    Imperial Valley
    Tacoma 1995 4x4
    how can i remove the belt..where are the bolts located?
