A/C compressor clutch bearing
Discussion in 'Technical Chat' started by Tacoma2525, Jun 6, 2012.
  1. Jun 6, 2012 at 9:50 AM
    Tacoma2525
    Tacoma2525 [OP] Member
    03 tacoma prerunner
    I have a 2003 tacoma pre-runner that when the A/C is on makes a thumping noise. I have found the problem on the clutch of the compressor. All it needs is the clutch bearing. Does anyone know right off what the bearing number is for the clutch?
  2. Jun 8, 2012 at 6:45 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    You can download the Factory Service Manual .
    Frank
  3. Jun 9, 2012 at 1:08 PM
    bones63
    bones63 Member
    Bones
    youngstown ohio
    02 Tacoma SR5
    none
    I got an 2002 Tacoma 6cyl 4x4 with a bad clutch bearing also. Its a Nachi 593 30BGS10DST. Don't know if they are the same thought. A guy at autozone ordered me one for $18.00
  4. Jun 9, 2012 at 2:27 PM
    Tacoma2525
    03 tacoma prerunner
    Yea thats where I ended up getting mine. However, it did not fix my problem. What is your compressor doing? Im thinking its going to have to be replaced on mine. It only has 112,000 miles on it though
  5. Jun 10, 2012 at 7:32 AM
    bones63
    bones63 Member
    Bones
    youngstown ohio
    02 Tacoma SR5
    none
    Mine has about the same mileage. Its been doing it for about two years. Going to sell it so i thought i better fix it. It makes the sound of a power steering pump that has gone bad. Its a big job......expensive repair at the dealer.
  6. Jun 10, 2012 at 4:08 PM
    Tacoma2525
    03 tacoma prerunner
    Did you just replace the whole compressor ? And did that fix the problem? Yea mines going on a year im not sure if its a pulley or what
  7. Jun 11, 2012 at 10:27 AM
    bones63
    bones63 Member
    Bones
    youngstown ohio
    02 Tacoma SR5
    none
    Haven't finished the job yet. Will let you know.
  8. Jun 19, 2012 at 4:15 AM
    bones63
    bones63 Member
    Bones
    youngstown ohio
    02 Tacoma SR5
    none
    put new bearing in the clutch on the a/c compressor & it sounds good now.
  9. Apr 3, 2014 at 11:46 PM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    If you guys are still on the forum can you give me an update? Bones was your making a knocking noise when the ac was on? If so is that all you replaced was the bearings to which you listed the part number? And Tacoma2525 did you ever get it fixed? If so what did you do? Mine is making a knocking noise sometimes when the ac is on. The pulley wobbles some too.
  10. Jun 4, 2014 at 4:07 PM
    Doctor1143
    Doctor1143 New Member
    Ed
    Austin TX
    02 PreRunner 4-cyl 2.7L
    None
    I'm experiencing the same problem on my '02 Tacoma PreRunner. The bearing on the clutch plate is obviously wallowed out causing the pulley to wobble when under load. Replacing the bearing seems an obvious fix without replacing the entire clutch. What is the replacement bearing and who is a reasonable source, AutoZone?
  11. Jun 5, 2014 at 7:39 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    I ordered mine from someone off eBay because I couldn't find the bearing in any store near my house. I don't remember the number on it but I can look when I get home. I haven't had a chance to put it in yet either.
  12. Oct 13, 2015 at 4:54 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    Another thead revival. Any fixes?
  13. Oct 13, 2015 at 7:11 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    You can test the bearing easily. Use a ratchet to hold the tensioner with some slack and pull the belt off the AC. Now spin the pulley. If it is quiet and smooth, and has no play, it's not the problem. When they go bad, they generally feel very rough when you spin by hand.
