A/C Compressor Clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mike157, May 31, 2018.
  1. May 31, 2018 at 12:30 PM
    Mike157
    Mike157 [OP] New Member
    2014 TRD Off Road
    Today was the first warm day of the year and I turned on the a/c and it was not blowing any cold air. I can recall smelling burning rubber a couple times this winter and for a while every time I started the truck the a/c light would be blinking but eventually that stopped.
    I checked some things today, swapped the relay with another and confirmed that was not the problem then noticed this.
    You can see the rubber bunched up/ out of place on the bottom.
    Can just the clutch be replaced? If so where can I get one? Checked at napa and only the whole compressor with clutch can be bought, about $500 for a refurbished one or close to $1000 for a new one plus whatever it would cost for recharging the refrigerant afterwards.
    I bought the truck last fall used from a dealer, 2014 TRD Off Road 37,000 Km on it when I bought it and about 50,000 Km on it now. Seems ridiculous that the A/C Clutch would fail within 50,000 KM not happy about this at all.
  2. May 31, 2018 at 12:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lots of info on this already. Google your question with tacomaworld in the title
  3. May 31, 2018 at 3:41 PM
    Snotrocket
    Snotrocket Well-Known Member
    Maine
    2022 TRD OR DCLB
    Any chance it's still under warranty? It's only 4 years old and has low mileage.
    I believe I read that just the clutch can be replaced but I don't have the thread bookmarked.
    My compressor went out on my 2009 last summer and I changed it out.
    You'll need a manifold gauge set and a vacuum pump if you go that route.
  4. May 31, 2018 at 3:47 PM
    Clearwater Bill
    Billy
    Largo Florida
  5. May 31, 2018 at 3:52 PM
    Mike157
    2014 TRD Off Road
    Nope it's out of warranty, like b_r_o suggested above I done some searching and it can be replaced and found some listings on ebay out of the U.S. where I could get one for around $200 with shipping. I'm going to talk to the dealership I bought it from and see if they'll do anything for me, it was october when I bought it with the warm weather long gone so I haven't really even used the A/C. They're a 10 hr drive from me so even if they just sent me the part I'd be happy.
  6. May 31, 2018 at 3:55 PM
    Mike157
    2014 TRD Off Road
  7. May 31, 2018 at 4:15 PM
    fs007
    fs007 Well-Known Member
    06 AC 4x4 4cyl
    I am working to have the same issue fixed right now. Got quoted from Toyota today... they want 1500 for oem parts (compressor and clutch) or 1000 for an aftermarket install. Apparently you can buy a compressor/clutch together...200 on Amazon....my local shop told me 2hrs Labor for the instal...that’ll definitely be cheaper than the stealership
  8. May 31, 2018 at 4:15 PM
    fs007
    06 AC 4x4 4cyl
  9. May 31, 2018 at 4:30 PM
    Mike157
    2014 TRD Off Road
    What's your mileage? I've never had issues with a/c on anything else I've owned, had a focus with 260,000 on it never a problem with it and I've got 23yr old sports car with ice cold a/c. Hopefully this is not something that will turn up every 50,000 I plan on keeping the truck for a long time.
  10. May 31, 2018 at 4:58 PM
    fs007
    06 AC 4x4 4cyl
    My truck has 160k
    But I bought it used a year ago with the ac not working
    It’s just crazy what the dealer will charge... my abs light is intermittently on... and it’s because of a slightly broken cable that need to be mended...they said they can’t repair it and told me i need a new harness for then engine bay...quote = 3300
  11. May 31, 2018 at 5:54 PM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Clutch hub. Order the clutch hub from ebay for 50 bucks. Exactly the same thing happened to me 3 weeks ago and that 50 dollar part and 15 minute fix resolved the problem. The rubber on the hub fails. Try it!
